Page 1 of 2
[solved] Errors starting on fresh Debian 10 install
Posted: Fri Apr 09, 2021 12:32 am
by superweasel
I started with a fresh install of Debian 10, then followed these instructions:
https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
I get an error when starting zoneminder:
root@zoneminder-be:~# systemctl start zoneminder
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
root@zoneminder-be:~# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-04-08 17:26:16 PDT; 4s ago
Process: 4675 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
There are no useful errors in /var/log/zm/. However, the jobs do seem to be running:
root@zoneminder-be:~# ps axuw | grep zm
www-data 3170 0.0 0.2 33936 16520 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
www-data 3200 0.0 0.4 49092 35508 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
www-data 3207 0.0 0.4 49096 35488 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
www-data 3215 0.0 0.2 33412 19676 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmwatch.pl
www-data 3222 0.0 0.4 54080 40256 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
www-data 3228 0.0 0.2 33192 19536 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmstats.pl
root 4944 0.0 0.0 6076 884 pts/0 R+ 17:29 0:00 grep zm
I actually started with a Debian 10 system with Zoneminder-1.34.23 installed where it was mostly working but had these same symptoms. I reinstalled the OS in hopes of clearing this up, but it's still broken for me. Any pointers of how to debug this would be most appreciated.
Re: Errors starting on fresh Debian 10 install
Posted: Tue Apr 13, 2021 4:34 pm
by superweasel
Is there a good way to increase verbosity so that I can see what's causing the errors?
Posted: Tue Apr 13, 2021 7:13 pm
by techman93098
I'm having the same issue as well, hope there is a fix soon we desperately need our security cameras to work!
Posted: Wed Apr 14, 2021 6:03 am
by Magic919
Try the logging settings in the web interface. See if you can turn them up a bit.
Posted: Wed Apr 14, 2021 8:30 am
by gruiarew
Posted: Wed Apr 14, 2021 7:41 pm
by superweasel
I looked at that. I tried uncommenting the '#User=www-data', but that didn't help. The last post in that thread suggests that things should work with a clean install, but that was not the case for me.
Magic919 wrote: ↑Wed Apr 14, 2021 6:03 am
I'll give this a try next, thanks.
Posted: Wed Apr 14, 2021 9:02 pm
by superweasel
I found two issues in the logs. First:
WAR Cannot write to event folder /var/cache/zoneminder/events. Check that it exists and is owned by the web account user.
I fixed that with
# mkdir /var/cache/zoneminder/events
# chown www-data.www-data /var/cache/zoneminder/events
That one may have been my fault because I had configured a separate partition to be mounted on /var/cache/zoneminder. I'm still surprised that it's not able to create this directory itself (it has write permissions to /var/cache/zoneminder).
The other problem was
ERR ZoneMinder is not configured properly: php's date.timezone is not set to a valid timezone. Please check Options->System->Timezone
which I fixed by setting the tomezone under Optios as suggested.
Overall I find it slightly confusing to encounter an error at the OS level (the zoneminder service won't start) and have the relevant error messages only within the application. I expected to find them in system logs.
Now to reconfigure my cameras. Thanks for the help.
Re: [solved] Errors starting on fresh Debian 10 install
Posted: Mon Oct 04, 2021 5:42 pm
by BobLaske
In my case of a brand new install of 1.34.26 on a freshly installed Ubuntu 20.02 LTS server, I still get the error every minute or so.
I already set the time zone in the Options and know my permissions are set too.
chown -R www-data:www-data /etc/zm
chown -R www-data:www-data /var/cache/zoneminder
chown -R www-data:www-data /var/log/zm/
Since that didn't fix it, I went ahead and edited the php.ini file to include the timezone as well.
Since editing /etc/php/7.4/apache2/php.ini didn't work, I went ahead and also edited /etc/php/7.4/cli/php.ini.
ie: date.timezone = America/Chicago
I restarted the web and zm services and still no change.
Why am I still seeing this error? Someone who is not very familiar with working on the OS would be lost.
10/04/21 10:38:02.121227 web_php[3750].ERR [192.168.1.205] [ZoneMinder is not configured properly: php's date.timezone -0700 does not match the system timezone +0000! Please check Options->System->Timezone.] at /usr/share/zoneminder/www/includes/functions.php line 2423
Posted: Tue Oct 05, 2021 12:39 am
by kitkat
BobLaske wrote: ↑Mon Oct 04, 2021 5:42 pm
What does
ls /etc/localtime show?
If it's a symlink, which is how CentOS does it, then make sure it points to (something like)
/usr/share/zoneinfo/America/Chicago or if it's a file then replace it with the relevant file from /usr/share/zoneinfo/...
That might fix it.
Posted: Tue Oct 05, 2021 11:42 pm
by BobLaske
Yes, it's already linked.
lrwxrwxrwx. 1 root root 37 Dec 2 2020 localtime -> ../usr/share/zoneinfo/America/Phoenix
# cat /etc/localtime
TZif2
▒▒▒:▒▒▒▒▒▒▒▒▒▒ˉ
▒▒▒Ϗ▒Ё▒▒u▒▒X▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
LMTMDTMSTMWTTZif2
▒▒▒▒▒▒▒:▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ˉ
▒▒▒▒▒▒▒▒▒▒▒Ϗ▒▒▒▒▒Ё▒▒▒▒▒▒u▒▒▒▒▒▒X▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
LMTMDTMSTMWT
MST7
Posted: Wed Oct 06, 2021 7:44 am
by Magic919
Run timedatectl and see what it says. You should be able to set it via that and get rid of the errors.
Posted: Wed Oct 06, 2021 4:33 pm
by BobLaske
Oddly, this shows UTC time and not the MST one I have set.
# timedatectl
Local time: Wed 2021-10-06 16:31:03 UTC
Universal time: Wed 2021-10-06 16:31:03 UTC
RTC time: Wed 2021-10-06 16:31:04
Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
So, I know I can set it from the OS to fix this but mainly, my question is what about those that aren't so familiar with the terminal?
Why this is happening is what needs to be addressed so that zoneminder itself isn't throwing these errors out.
Posted: Wed Oct 06, 2021 5:35 pm
by Magic919
Server timezone is not correctly set. It doesn’t match what’s set in the ZM UI. ZM logs this as an error with a clear explanation. Doesn’t sound like a ZM problem.
Posted: Wed Oct 06, 2021 6:03 pm
by BobLaske
Wait, you're right.
Mine was a ubuntu embedded build so it comes pre-installed and yes, that and some other things need to be set at the OS level.
However...
# sudo timedatectl set-ntp true
# timedatectl set-timezone "America/Chicago"
# timedatectl status
Local time: Wed 2021-10-06 13:00:10 CDT
Universal time: Wed 2021-10-06 18:00:10 UTC
RTC time: Wed 2021-10-06 18:00:11
Time zone: America/Chicago (CDT, -0500)
NTP service: active
RTC in local TZ: no
# sudo systemctl restart systemd-timesyncd.service
# tail -f /var/log/zm/web_php.log
10/06/21 10:52:13.442603 web_php[106475].ERR [192.168.1.205] [ZoneMinder is not configured properly: mysql's timezone does not match the system timezone! Event lists will display incorrect times.] at /usr/share/zoneminder/www/includes/functions.php line 2426
So, what else am I missing?
Posted: Wed Oct 06, 2021 6:29 pm
by Magic919
The error says MySQL has the wrong TZ. It probably picks this up from the OS when you start the daemon. Do a MySQL (d) restart.
