[solved] Errors starting on fresh Debian 10 install
BobLaske
Re: [solved] Errors starting on fresh Debian 10 install
Post by BobLaske »
Yes, I should have added that I did restart all the main components.
# systemctl restart mysql apache2 zoneminder
# tail -f /var/log/zm/web_php.log
10/06/21 11:44:06.162127 web_php[111621].ERR [192.168.1.205] [ZoneMinder is not configured properly: php's date.timezone -0700 does not match the system timezone -0500! Please check Options->System->Timezone.] at /usr/share/zoneminder/www/includes/functions.php line 2423
Same error in the log.
You have the correct one in the ZM UI, but it says the OS is set to a different one, -5 hours instead of -7. You can check and set it with the command mentioned previously.
BobLaske
Post by BobLaske »
Another good catch. When you stare at something too long, you start not seeing it.
I changed it to Chicago to test a while ago which is masmatched from the options.
Now it seems to be fine.
Great, that's one less error and my final one to solve is why zoneminder keeps getting a database server missing error here and there.
Thank you.
kaiserzop
Post by kaiserzop »
Run timedatectl and see what it says. You should be able to set it via that and get rid of the errors. techzpod stream free movies
