text frame 'Unable to stream' in 1.35.23
muebbel
Post by muebbel »
If i use ffmpeg with decoding enabled everything works, but if i disable decoding i get a image with "unable to stream".
I cant find the source for the problem, only some logs which tells "there is a problem":
debug.log:
04/06/21 10:44:57.165983 zms_m1[12116].DB1-zm_logger.cpp/224 [LogOpts: level=DB2 effective=DB2, screen=OFF, database=INF, logfile=DB2->/var/log/zm/debug.log, syslog=OFF]
04/06/21 10:44:57.166969 zms_m1[12116].INF-zm_user.cpp/126 [Authenticated user 'admin']
04/06/21 10:44:57.167097 zms_m1[12116].DB1-zm_utils.cpp/198 [Detected a x86\x86-64 processor with AVX2]
04/06/21 10:44:57.167219 zms_m1[12116].DB2-zm_stream.h/209 [Setting replay_rate 100]
04/06/21 10:44:57.169145 zms_m1[12116].DB1-zm_storage.cpp/91 [No id passed to Storage constructor.  Using default path /var/lib/zoneminder/events instead]
04/06/21 10:44:57.169209 zms_m1[12116].DB1-zm_monitor.cpp/475 [Have camera type Ffmpeg]
04/06/21 10:44:57.169235 zms_m1[12116].DB1-zm_monitor.cpp/2374 [Reloading linked monitors for monitor Parkplatz, '(null)']
04/06/21 10:44:57.169284 zms_m1[12116].DB1-zm_packetqueue.cpp/759 [Setting pre_event_video_packet_count to 1]
04/06/21 10:44:57.169311 zms_m1[12116].DB1-zm_packetqueue.cpp/753 [Setting max_video_packet_count to 81]
04/06/21 10:44:57.169336 zms_m1[12116].DB1-zm_monitor.cpp/639 [mem.size(8) SharedData=760 TriggerData=560 VideoStoreData=4128 timestamps=160 images=10x8294400 = 82944000 total=82949672]
04/06/21 10:44:57.169369 zms_m1[12116].DB1-zm_monitor.cpp/685 [Loaded monitor 1(Parkplatz), 0 zones]
04/06/21 10:44:57.169634 zms_m1[12116].DB1-zm_monitor.cpp/956 [Unable to map file /dev/shm/zm.mmap.1 (82949672 bytes) to locked memory, trying unlocked]
04/06/21 10:44:57.169684 zms_m1[12116].DB1-zm_monitor.cpp/959 [Mapped file /dev/shm/zm.mmap.1 (82949672 bytes) to unlocked memory]
04/06/21 10:44:57.169735 zms_m1[12116].DB2-zm_camera.cpp/66 [New camera id: 1 width: 1920 line size: 7680 height: 1080 colours: 4 subpixelorder: 8 capture: 0]
04/06/21 10:44:57.169837 zms_m1[12116].DB1-zm_stream.cpp/311 [Trying to open the lock on /var/run/zm/zms-087080.lock]
04/06/21 10:44:57.169890 zms_m1[12116].DB1-zm_stream.cpp/334 [We have obtained a lock on /var/run/zm/zms-087080.lock fd: 6]
04/06/21 10:44:57.170046 zms_m1[12116].DB1-zm_monitor.cpp/956 [Unable to map file /dev/shm/zm.mmap.1 (82949672 bytes) to locked memory, trying unlocked]
04/06/21 10:44:57.170086 zms_m1[12116].DB1-zm_monitor.cpp/959 [Mapped file /dev/shm/zm.mmap.1 (82949672 bytes) to unlocked memory]
04/06/21 10:44:57.170150 zms_m1[12116].DB1-zm_stream.cpp/76 [Monitor is not decoding.]
04/06/21 10:44:57.170176 zms_m1[12116].DB2-zm_stream.cpp/252 [Sending 1920x1080 * 100 text frame 'Unable to stream']
dmesg:
[80549.311944] traps: nph-zms[12015] trap divide error ip:562c5f6b10f4 sp:7ffd0e34fc80 error:0 in zms[562c5f634000+154000]
Any suggestions to solve this? :)
UPDATE
If i change the function from "nodect" to "record" the captured video is correct saved and playable... only the live-view wont work (doesnt matter if nodect or record).
Re: text frame 'Unable to stream' in 1.35.23
I find changing the source type restores live view.
E.G., Ffmpeg -> Libvlc -> Ffmpeg (with decoding enabled) restores the stream. Scary stuff.
muebbel
Post by muebbel »
dougmccrary wrote: Wed Apr 07, 2021 1:12 am E.G., Ffmpeg -> Libvlc -> Ffmpeg (with decoding enabled) restores the stream. Scary stuff.
Yeah, like i telled, if u enable decoding, its working fine...but with the known CPU usage...
If you want to view the image you have to decode (for now).
muebbel
Post by muebbel »
OK, thx for this important info :)
Is there any timeline or something to add the "no-decode-view"-feature? :)
compsol
Post by compsol »
I don't have an option for ffmpeg decode, is there another place in the config to enable this.
my list has:
local
remote
file
ffmpeg
libvlc
curl (http(s) only)
web site
nvsocket
VNC
On other "tabs" i have several options for ENCODE. but nothing anywhere for DECODE
Same model camera is working on my 1.28 zm machine just fine.
compsol
Post by compsol »
UPDATE:
removed database and switched out mysql for mariadb and ran zm_create and added user.
added camera again and this time I have working live view for both thumbnail and montage.
events have quit working now but I think it may be permissions from not deleting the events folder from the previous database.
SBCDave
Post by SBCDave »
I also am not sure what you mean by "with decoding on", and I'm having this same problem with an Annke 6MP camera. I tried switching to libvlc and back (even restarted zm each way) but no luck. Any advice is appreciated. I have my recordings but can't live stream in browser or zmninja. It worked when I first set it up, but a month or two later it just gives the unable to stream error on a black screen now. I have similar log entries.
SBCDave
Post by SBCDave »
Bump. Hoping for info on how to turn on decoding. Thanks for any help
muebbel
Post by muebbel »
This threat was created to get a info for "how to view videos from cams without the need of enable decoding" and now here are questions about "how to enable decoding"...
The option to view the cams WITHOUT decoding the stream will give a great benefit to ZM (much less CPU usage) if the cams can trigger a userdefined cmd on a alert.
I hope we will get this feature soon.
Might be better posting a new thread in the current Dev version 1.37.
Don't post a thread unless you are willing to fund it.
