Hello, i am searching for an option, that shows the last event always on top of the event list. By default the latest event is listed at the end of the list and i can switch vice versa by clicking the time column manually. This is annoying, because i want directly displayed the last event on top of the event list. I can`t find any option in the zoneminder configuration, so is there any other possibility to switch the eventslist listing ( perhaps by editing configfiles ) ?
regards
[solved] Eventsoverview - last event on top
- knight-of-ni
Re: Eventsoverview - last event on top
WEB_EVENT_SORT_ORDER
From the documentation:
https://zoneminder.readthedocs.io/en/st ... ptions-web
NOTE:
In the next release, sorting will happen by simply clicking on the column header you want to sort on.
NOTE:
