Checking all the Android App with RTSP server
SirLouen
Post by SirLouen »
I've been testing so far many apps but any of them are stable enough or have enough functionality
1. RTSP Camera Server: https://play.google.com/store/apps/deta ... l=en&gl=US
Doesn't provide RTSP auth! Useless
2. VXG RTSP Server: https://play.google.com/store/apps/deta ... l=en&gl=US
3. Astra Streaming Studio: https://play.google.com/store/apps/deta ... l=en&gl=US
Very promising but after 30 minutes of streaming, a message appears in the middle of the screen Source Timeout and can't keep streaming with a RTSP streaming. Essentially, the cam gets corrupted and requires an Android softboot. Still, with a more conservative bitrate, it's slightly more stable. To remove the watermark it costs $10
4. Free Security Camera: https://play.google.com/store/apps/deta ... l=en&gl=US
The icon is a joke, but so far, the only stable RTSP camera with auth. I'm missing many of the functionality of the Astra Streaming Studio, but at least it works. The video output although, is not good, blurs too much.
5. CamON Live Streaming: Amazing piece of software. It has plenty of functionality similarly to Astra Streaming Studio, and is 100% free, though it runs with ads. If I were confident with JAVA Android programming it would be worth a fork to be introduced as an "official" app for the Zoneminder project. This guy has even thought in one of the most interesting functionalities embedded within, I've always had to solve with 3rd party apps: syncing dynamic 4G IP with dynamic DNS updaters. It's based on this abandoned project by Muhammad Zia Shahid https://github.com/boygaggoo/spynet-camera. It can be self-compiled and it will be from ads, but it won't have the whole CamON functionality which is updated regularly (due to the ad revenue) while the spy-net Cam GPL project was abandoned 4 years ago. The only issue that CamON doesn't offer is the timestamping straightly from the source. If you are going to go pass-through you won't have timestamps embedded on the recording which is a pity. I've contacted the developer, and he doesn't even know how to put them. For some type of video surveillance purposes the timestamps are a requirement, so unless you encode in the server and put the timestamp via ZM you will have an issue in this aspect.
Conclusions up to now (22/4/21):
CamON Live Streaming is the best alternative if you want to record with the pass-through option which need a RTSP stream to be stable enough. I've noticed that after some tweaks on the mobile side, Astra Streaming Studio can also gain a lot more stability and maybe paying the extra bucks is worthy.
It's just important to set the bitrate to the minimum viable, since going 1080p 60fps unless we are using a powerful phone (something above Snapdragon 835), it will get locked. It's better to fly lower with 720p 30fps or even less for old/cheap phones (720p 10fps).
Other Honourable Mentions:
- IP Webcam
- DroidX
... not RTSP
If anyone knows more alternatives to be tested, please post them here and I will be checking them!
Thanks!
Re: Checking all the Android App with RTSP server
This is a great resource.
SirLouen
Post by SirLouen »
Updated with CamON Live Streaming experience.
SirLouen
Post by SirLouen »
Updated with new conclusions
AdamAfonso
Post by AdamAfonso »
This application is outdated and not supported!
Please use the new application "Astra Streaming Studio".
https://play.google.com/store/apps/deta ... iv.astudio
RTSP Server which is able to serve live or recorded camera view to RTSP clients.
-Loop video recording
-Quick capture method
-Work in background as a service
-Support the different camera resolutions and fps
-You can choose between the back facing camera and the front facing camera
-Encoders H264 and ACC
View video on your computer.
Install VLC http://www.videolan.org
Menu->Media->Open Network Stream... enter http://(device ip address):8080/playlist.m3u
Open the playlist (hotkey Ctrl + L).
Single command URL:
Active camera - rtsp://(device ip address):5554/camera
Back camera - rtsp://(device ip address):5554/back
Front camera - rtsp://(device ip address):5554/front
Camera URL Parameters:
res Resolution - width(number)xheight(number)
fps Frame per second - fps(number)
mic Enable/Disable microphone - on(string) or off(string)
Example: rtsp://(device ip address):5554/back?res=640x480&fps=10&mic=on
All records - rtsp://(device ip address):5554/record
One hour of record from specified time - rtsp://(device ip address):5554/recordYYMMDD_hhmm
Specified duration of record from specified time - tsp://(device ip address):5554/recordYYMMDD_hhmm-hhmm
Last record, duration in hours and minutes - rtsp://(device ip address):5554/record-hhmm
5554 ~554? But I think you'll find that's not needed, unless like some cams it's at 8554, or maybe rtmp which I don't know about.
