VNC: Error Loading libvncclient shared library not found
burger
Post by burger »
On debian 10 / devuan 3, in 1.35.20~20210309.53-buster I see the following error for libvncclient shared libraries:
03/12/21 21:57:43.790746 zmc_m2[8088].ERR-zm_libvnc_camera.cpp/26 [Error loading libvncclient: libvncclient.so: cannot open shared object file: No such>
03/12/21 21:57:43.790953 zmc_m2[8088].INF-zmc.cpp/221 [Starting Capture version 1.35.20]
03/12/21 21:57:43.823899 zmc_m2[8088].ERR-zm_signal.cpp/49 [Got signal 11 (Segmentation fault), crashing]
03/12/21 21:57:43.824054 zmc_m2[8088].ERR-zm_signal.cpp/81 [Signal address is (nil), no instruction pointer]
03/12/21 21:57:43.824245 zmc_m2[8088].ERR-zm_signal.cpp/100 [Backtrace 0: /usr/bin/zmc(+0xc395a) [0x5630d59ef95a]]
03/12/21 21:57:43.824300 zmc_m2[8088].ERR-zm_signal.cpp/100 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12730) [0x7f65eddcc730]]
03/12/21 21:57:43.824349 zmc_m2[8088].INF-zm_signal.cpp/107 [Backtrace complete, please execute the following command for more information]
03/12/21 21:57:43.824488 zmc_m2[8088].INF-zm_signal.cpp/108 [addr2line -e /usr/bin/zmc 0x5630d59ef95a 0x7f65eddcc730]
So I checked. The dependency for libvncclient1 is already satisfied in the controls for the zm debian package.
so i needed a symlink from
/usr/lib/x86_64-linux-gnu/libvncclient.so.1
to
as the so file does not exist in buster.
I installed tightvnc on windows, with a view only user. In ZM, there is no requirement to set the
username. I did set a password. I set the FPS limit to about 3, as by default its 80FPS.
It was using up 80% of the core 2 cpu. So a limit is advised for VNC. At 3 fps, load is about 6%. FPS Limit seems to work, as in local mode. I tested jpeg, and h264 encoding. No issues there.
See attached for some graphical glitches in the pale moon browser, and an example configuration for reference. Overall, it looks solid.
fastest way to test streams:
burger
Re: VNC: Error Loading libvncclient shared library not found
Post by burger »
Also, there is an issue with the DB creation on buster / devuan. It looks like whatever dpkg is doing in zoneminder.postinst is failing. What happens is that the numbers don't show in the web console for day,week,month, etc for a monitor. They do show totals. When I try to run the zm_create.sql I get the following error below. This is resolved with a drop database zm; and recreating the db from scratch as shown. To be clear, I have Mariadb.
# mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
ERROR 1050 (42S01) at line 1042: Table 'Sessions' already exists
(in mysql)
drop database zm;
(then)
