Stepping through zmeventnotification setup
Support for the docker image maintained by dlandon
tlundste
Post by tlundste » Tue Mar 02, 2021 5:04 am
I'm trying to go through the setup to enable better notification via the YOLO, FACE, options, etc... I'm tired of partly-cloudy windy days running shadows fast across my zones and setting off event detection. And, I want to play with the "person" "dog" "car" etc object detection.
First of all... after I enabled the "=1" settings of my ZM image/container, it takes nearly an hour to start the image and container. Most of it is waiting on "compiling opencv without GPU support" (that step alone is around 40 minutes!). But, it comes up.
First question... is there something I can do to speed up the start-up of the container?
Second question... What am I missing to open up "https://<myIP>:9000/zm"? I just get "this page is not working". If I go to :9080, the apache webserver main page comes up. If I go to ":9443", I get my main Zoneminder interface. But nothing at port 9000.
Initially, when I brought up the container after setting the values in the container for YOLO, etc to =1, port 9000 was listening in my Ubuntu host, but when I "exec'd" into the container, port 9000 was not listening, nor was zmeventnotification.pl running. I did some digging, enabled opt_use_eventnotification in ZoneMinder's options via the web interface, and restarted the image and container. This time, I could see port 9000 listening and the .pl file running inside the container. Yet, I still can't get to that :9000 webpage.
Here is my config...
Ubuntu LTS 20.04.1 LTS
Hardware is a NUC8i3
Running docker, with docker-compose setup.
Zoneminder functions just fine. Here are the relevant docker-compose.yaml sections.
############# ZONE MINDER
 zm_db:
   container_name: zm_db
   restart: always
   image: mysql/mysql-server:latest
   environment:
     - TZ=America/Chicago
     - MYSQL_USER=zmuser
     - MYSQL_PASSWORD=zmpass
     - MYSQL_DATABASE=zm
     - MYSQL_ROOT_PASSWORD=mysqlpsswd
     - MYSQL_ROOT_HOST=%
   network_mode: znet
 zoneminder:
   container_name: zoneminder
   image: dlandon/zoneminder:latest
   restart: unless-stopped
   depends_on:
     - zm_db
   shm_size: 4096m
   ports:
     - 9443:443/tcp
     - 9000:9000/tcp
     - 9080:80
   network_mode: znet
   environment:
     - ZM_DB_HOST=zm_db
     - SHMEM=50%
     - PUID=99
     - PGID=100
     - INSTALL_HOOK=1
     - INSTALL_FACE=1
     - INSTALL_TINY_YOLOV3=0
     - INSTALL_YOLOV3=0
     - INSTALL_TINY_YOLOV4=1
     - INSTALL_YOLOV4=0
     - MULTI_PORT_START=0
     - MULTI_PORT_END=0
   volumes:
     - /mnt/server/zoneminder:/config:rw
     - /mnt/server/zoneminder/data:/var/cache/zoneminder:rw
I've done nothing with the supplied .ini files, yet... Should I be able to get to the :9000 page without modifying any of the .ini files, first? If not, what needs modifying?
Re: Stepping through zmeventnotification setup
Post by Magic919 » Tue Mar 02, 2021 8:49 am
Port 9000 is not a web page. It's for communication with ZMES.
tlundste
Post by tlundste » Tue Mar 02, 2021 1:52 pm
OK... thank you. I'll keep reading to see if I can figure out what's next, then. I thought I saw someone post that :9000 as a means to access something within, via a web browser.
Still looking to find out if there is a way to start up my container more quickly. Before enabling the "YOLO" and other settings, it would start in a few minutes... now, it's nearly an hour.
Post by Magic919 » Tue Mar 02, 2021 2:46 pm
If part of the startup is that it downloads the source, configures and then builds Opencv, then it'll take a while. If the build is not optimised to use all the available cores and/or the machine lacks grunt it'll only be worse.
If the next steps involve it installing Yolo and other ZMES goodness, then more of the above. This bit is much smaller impact than the Opencv step.
tlundste
Post by tlundste » Tue Mar 02, 2021 7:42 pm
Well, after doing some more reading... what I've started to do has been abandoned, anyway, and it looks like he (dlandon) is working up a new, more consolidated install. I'll keep an eye on that one, and then try to figure out how to convert over to it. For now, I'll remove my "=1" entries, and go back to the much faster start up time.
Post by Magic919 » Tue Mar 02, 2021 8:04 pm
He mentioned it in this thread viewtopic.php?f=41&t=30376 Abandoned might not be a good description.
tlundste
Post by tlundste » Tue Mar 02, 2021 9:45 pm
Abandoned / Deprecated
To-ma-yto / To-mah-to.
No harm, or disrespect was intended in my comment... just that it's not a way to move forward anymore... no sense in struggling to configure something that isn't going to (likely) change with the times. Might as well wait for a more elegant solution (for now). I'm just playing, anyway... only got one camera.
