Mysql memory calculator, check my math Plz
rknobbe
Post by rknobbe » Mon Jan 25, 2021 4:14 pm
I've been getting oom-killer messages since I added a new camera. Rather than use a calculator to try to add up the total memory required, I figured I'd let MySQL do the work.
Somebody please check my math. Maybe others will benefit from the mysql script.
mysql> select x.Id, x.Width, x.Height, x.ImageBufferCount, x.Colours, x.BufferSpace as BufferMB, 1.2*sum(x.BufferSpace) over (Order by Id) as RunningTotalMB_w_OH from (select Id, Width,Height,ImageBufferCount,Colours,(W
idth*Height*ImageBufferCount*Colours/1024/1024) as BufferSpace  from Monitors order by Id) x;
13 rows in set (3.46 sec)
burger
Re: Mysql memory calculator, check my math Plz
Post by burger » Mon Jan 25, 2021 9:03 pm
Very cool. I added to wiki.zoneminder.com/MySQL. Not sure if this addresses the difference between ZMA and ZMC though. In my case, Htop says ZMC -m36 below (Record only) has 6% of memory while ZMA -m7 has 5% of memory. The numbers below don't line up. (Not that I know what I'm talking about).
ZMC == record
ZMA == analysis/motion detection
You can verify a given process memory use via /proc/<pid>/status ofc.
|  1 |  1280 |    720 |               50 |       4 |  175.78125000 |       210.937500000 |
|  4 |   800 |    600 |               50 |       4 |   91.55273438 |       742.675781256 |
|  5 |  1280 |    720 |               50 |       4 |  175.78125000 |       953.613281256 |
|  6 |   800 |    600 |               50 |       4 |   91.55273438 |      1063.476562512 |
|  7 |  1280 |   1024 |               50 |       4 |  250.00000000 |      1363.476562512 |
| 10 |   800 |    600 |               50 |       4 |   91.55273438 |      1473.339843768 |
| 11 |  1280 |    720 |               50 |       4 |  175.78125000 |      1684.277343768 |
| 14 |  1280 |    720 |               50 |       4 |  175.78125000 |      2317.089843768 |
| 15 |  1280 |    720 |               50 |       3 |  131.83593750 |      2475.292968768 |
| 17 |   704 |    480 |               50 |       4 |   64.45312500 |      2552.636718768 |
| 18 |   704 |    480 |               50 |       4 |   64.45312500 |      2629.980468768 |
| 21 |  1280 |    720 |               50 |       4 |  175.78125000 |      2840.917968768 |
| 24 |   352 |    240 |               50 |       4 |   16.11328125 |      3014.941406268 |
| 25 |   640 |    480 |               50 |       4 |   58.59375000 |      3085.253906268 |
| 26 |  1280 |    720 |               50 |       4 |  175.78125000 |      3296.191406268 |
| 27 |   800 |    600 |               50 |       4 |   91.55273438 |      3406.054687524 |
| 28 |   640 |    480 |               50 |       4 |   58.59375000 |      3476.367187524 |
| 29 |   800 |    600 |               25 |       4 |   45.77636719 |      3531.298828152 |
| 30 |  1280 |    720 |               50 |       4 |  175.78125000 |      3742.236328152 |
| 31 |   800 |    600 |               50 |       3 |   68.66455078 |      3824.633789088 |
| 32 |   800 |    600 |               50 |       4 |   91.55273438 |      3934.497070344 |
| 34 |   640 |    480 |              125 |       4 |  146.48437500 |      4220.141601600 |
| 35 |   640 |    360 |              100 |       4 |   87.89062500 |      4325.610351600 |
| 36 |  2560 |   1920 |              100 |       4 | 1875.00000000 |      6575.610351600 |
(Some entries have been removed for brevity)
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
If you are new to security software, read this:
