Need testers for ES code (multiple model chaining/ arbitrary frames)
Discussion topics related to mobile applications for ZoneMinder
Re: Need testers for ES code (multiple model chaining/ arbitrary frames)
Post by Magic919 » Wed Jan 06, 2021 8:28 am
I've pulled the latest version and moved to that and the migated config now.
Post by Magic919 » Wed Jan 06, 2021 11:38 am
Contradition regarding the default for use_sequence. The config file says
 NEW: If enabled (default = no), we will use ml_sequence and stream_sequence
Readthedocs says
When use_sequence is set to yes (default)
asker
Post by asker » Wed Jan 06, 2021 3:57 pm
Readthedocs says
fixed.
Please don't ask me questions via PM. Feel free to post in the forums or Github
Post by Magic919 » Wed Jan 06, 2021 4:15 pm
Thanks again. ZMES is exceeding my needs, but it's great that you've carried on extending it.
ranger21
Post by ranger21 » Wed Jan 06, 2021 5:05 pm
asker wrote:
Wed Dec 30, 2020 9:33 pm
The new version of ES support model chaining as well as inspecting multiple frames in an event.
I am looking for folks to:
1. Update to the new ES
2. Test if current operation works without making any config changes (that is, new code with old functionality)
3. Test new functionality.
Specifically, I want to know if folks update to the new ES and face any errors (without making changes to config)
Steps are here: https://github.com/pliablepixels/zmeven ... -749162186
Would appreciate feedback
default config for new detection sequence makes it to analyse faces all the time, so my cpu utilization sky-rocketed, i've added to face model config of ml_sequence "pre_existing_labels": person and now it's back to normal
it's not possible to setup different ml_sequences for certain monitors?
well, i have only CPU, so i can't test coral edge or gpu, but maybe i will try to do some ML_SEQUENCE with tiny_yolov4 and higher confidence number, then full yolo4 with lower confidence, but im not really memory bound.
asker
Post by asker » Wed Jan 06, 2021 5:53 pm
The default config is a sample. If you don't want face, simply remove it from model_sequence
It should work. You should be able to replace either variables or the full ml_sequence on a per monitor basis. Have you tried?
ranger21
Post by ranger21 » Sat Jan 09, 2021 4:24 pm
Yeah, global variables from [custom] section + replacing in monitors worked fine. Thank you.
