Linked Monitors and OD <Best Practice> Discussion
Posted: Sun Dec 06, 2020 12:02 am
I'm running 1.34.22 on UB20.04 server, NGINX/MariaDB (Discrete install not Docker). Running quite nicely, very stable, filters and cleanup work, very tolerant of cheap cams... Works well. GJ @Ic0n
I'm running ES&OD in the stock form from @asker. (Great work btw).
My question comes from the use of linked monitors. (Low-Res(352x240) Modect , Hi-Res (2560x1440) NoDect linked to Low Res)
Is anyone using OD in this configuration?
Do you run OD on the Low-Res monitor or the Hi-Res monitor?
If you are using the Hi-Res monitor for OD, which "frame_id=" option are you using? (bestmatch, alarm, snapshot)
If none of the above are true, did you just go with a Hi-Res Modect and run OD on that?
My concerns are:
1) The alarm value for the linked Hi-Res monitor is all the same (because it was triggered from the link), so how would OD know the best frame to get?
2) The Low-Res monitor will have the best frame_id's to choose from but the resolution is too low for good OD.
What are your thoughts and experiences?
To add a wrinkle, is anyone running a Mocord Hi-Res monitor linked to a Low-Res in Modect?
My concerns are:
