Advice for high quality still images from h264 stream
Posted: Fri Dec 04, 2020 8:09 pm
I'm looking for advice on the image quality front. I have a system that monitors a busy rural road corner and would like to do license plate detection, manual or automatic. In the manual case, the still image quality from a Amcrest 4k camera is barely enough. Remove storage size as a limitation ... what is the best way to get a high quality image from the h264 stream?
I have used the stills directly from the zoneminder UI and extracting images using ffmpeg from the event mp4 but the quality isn't great. If you had a 4k still image at 20 feet, license plate detection would be easy. I'm currently using 10 fps at full resolution (3840x2160) and variable bit rate. I've read that many license detection systems use 30+ fps. Are there some good rules to live by when trying to find the balance between size and quality?
Any input appreciated.
