Server slows down
oksiweles84
Server slows down
Post by oksiweles84 »
Sorry, the text was translated with the help of the Google translator.
The problem is as follows: there is Zoneminder v. 1.34.21, which has 70 cameras. The image quality in "Montage rewiev" mode is poor and cameras drop out periodically.
Server:
CPU: Intel (R) Xeon (R) CPU E5405 8 * 2.00GHz
Memory: 32 GB
No video cards.
Please advise what can be adjusted. Thank you.
burger
Re: Server slows down
Post by burger »
Sounds like you underspeced your server. Either add another server, or upgrade the hardware.
If you search around there may be some more tips on optimization. I thought there was a thread specific to montage recently, but regardless, there are always ways to lower CPU usage. See https://wiki.zoneminder.com/Dummies_Guide
fastest way to test streams:
oksiweles84 wrote: Fri Nov 20, 2020 3:37 am Sorry, the text was translated with the help of the Google translator.
Server:
Memory: 32 GB
No video cards.
First, lower the frame rate and resolution. 5 FPS at 640x480 or something like that. Yes, I know you invested in the high res cams but Zoneminder is not a 42 FPS movie camera system. And you can catch crooks at 5 FPS! Get it stable and push the settings higher to see waht happens.
If you want to continually monitor groups of cameras, set up a web page to show the cameras you want on a group and feed those web pages from Zoneminder. Can provide the code if needed.
