Questions about Zoneminder
mehenwolf24
Post by mehenwolf24 »
I've just recently switched over from iSpy on windows and I'm running in to some issues to reach feature parity. ZM seems to have a steep learning curve so I'm hoping someone can point me in the right direction on some questions.
Is there away to set a schedule for PTZ and to stop the monitoring software from recording on scheduled movement.
Is there away to set up motion tracking? For example, if a person works in to frame and continues moving towards the edge of the frame allowing the camera to keep that subject in the center of the frame.
Is there a good mobile interface for ZM? I'm a android user and I'd love to have access to my security system from my phone.
RockUser
Re: Questions about Zoneminder
Post by RockUser »
There's zmninja for the app. I use it and it's nice.
vnvideoeditor
Post by vnvideoeditor »
I have three Wyze Cam v2 running their RTSP protocol and I installed Zoneminder on a clean system with this script. my system is a vm with 8gb ram and 5 cores and nothing in htop uses more than 25%
vnvideoeditor
