Discolored live stream
Andyrh
Post by Andyrh »
I noticed that after the upgrade to 1.34.22 when I click to zoom a live stream the video sometimes "loses" a color, like a VGA monitor with a bad pin. Changing the zoom sometimes changes the lost color or restores to correct color. This occurs even when the camera is in B/W mode (still a color stream?) and will always happen if I keep zooming in.
This occurs on all cameras and only in live stream.
I cannot say it was the upgrade as I do not zoom often, but I did not see this before.
I am not sure where to start looking so I have made no changes yet.
ZM 1.34.22
Ubuntu 18.04
Amcrest cameras
Nothing logged
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
Andyrh
Re: Discolored live stream
Post by Andyrh »
I changed the color depth from 32bit to 24bit. The B/W streams seem fine. The color streams, not so much. It now substitutes colors.
I also removed the setting for DecoderHWAccelName with no change in behavior.
Any thoughts?
Thank you,
This is normal.
This is normal.
This is bluer than real life.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Only when zoomed? Sounds like we are using the incorrect colour space when generating the zoomed image.
I will have to try to replicate it I guess.
Edit: Easily replicated. Will fix soon.
Andyrh
Post by Andyrh »
Thank you for taking a look at it. The house looks better with red trim.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Andyrh
Post by Andyrh »
Still present in 1.34.23
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Stormeyes
Post by Stormeyes »
I get this too when i use zoneminders digital zoom (when you click somewhere in the image)
I have located the problem. The fix is in master and will be released in 1.34.24 soon.
Andyrh
Post by Andyrh »
Still present in 1.34.25
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Fixed finally in 1.34.26
Andyrh
Post by Andyrh »
Fixed in 1.32.26.
Thank you.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
