I would like to ask you if will be compatible and correctly work this cam Axis M3065-V witch zoneminder version 1.34.22.
Thanks for answer
Axis M3065-V
Re: Axis M3065-V
It's very likely that ZM will work with it. Axis typically have MJPEG and RTSP streams, so if one doesn't work (although they both probably will), you can use the other.
But, to be 100% sure, you'll have to buy one. See:
https://wiki.zoneminder.com/Hardware_Compatibility_List
https://wiki.zoneminder.com/Axis
ispydb
https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
I think Axis includes paths in user manual. From what I've seen, all the business tier Axis cameras work right out of the box without any issue. The low end Companion series work, but you must first configure the username/pass with Windows... Overall, 98% confidence it will work.
ispydb
fastest way to test streams:
Re: Axis M3065-V
Ok, thanks for help. We planning buy one and try it. But i think it will be correctly working with ZM. We try find good replacement for existing solutions from Sony. And i think the RTSP strem will be correctly work if i see in the documentation the another type like M3044-V.
