Are Docker install event alerts via SSMTP possible or is Event Server required?
Posted: Mon Oct 26, 2020 9:54 pm
Love ZM!.... and now with Docker!! - appreciative of the genius and effort put into creating this fantastic application!
My question for the good people of the forum:
I had ZM running for several years (straight install/Lubunu) with email notifications; all worked fantastic.
Upgraded to Lubuntu 20 recently and now trying ZM on Docker and love it.. but cannot get email notifications to work via ssmtp.
Read a bunch but couldn't find a straight answer so hoping someone can help answer a likely silly question directly:
For email notifications to work on Docker 'install', can I use ssmtp or does Docker require Event Server?
Context:
My manual tests from CLI (eg echo "Hello, World" | mail -s "My email check" user@gmail.com) work fine so ssmtp config is good.
Followed instructions to set up ssmtp (https://wiki.zoneminder.com/How_to_get_ ... Zoneminder).
But when I try to send email alert via ZM (eg filter/email details of all matches).. I get error in ZM log: "Unable to send email: error closing /usr/lib/sendmail: (exit 256)"... and no email alert
tail -f /var/log/syslog shows my successful manual CLI commands but nothing shows up regarding failed attempts via ZM.
Thanks so much for any insights!!
Context:
