FAT-zm_monitor.cpp 2324 [Bogus monitor type 'WebSite' for monitor 7]
Posted: Tue Aug 18, 2020 1:39 am
Hi, all.
I did an update from 1.34.4 to 1.34.19 and now things have gone weird.
None of my WebSite monitors are displaying in Montage, though individually each monitor works fine and after clearing my logs, nothing showed up in them.
I then tried restarting but that just made things even stranger - the FPS for the two remaining monitors which work (10 & 11, which were running at 2fps) are now around 40fps.
I saw this error about one of the non-working website monitors:
Can't find anything after a forum search. (Had to remove the forward slash as it caused phpBB to bork.)
My error log is now full of:
(Incidentally, what's the 'zone window'?)
These appeared after the reboot:
But both monitors 10 & 11 are working fine!
tl;dr: 5 [Bogus?] 'WebSite' monitors stopped working after update , but show no errors. It guess it wouldn't show zms/zmc warnings as WebSite 'streams' are not analysed. 2 working monitors stream but are generating failure errors.
If you need any information let me know what to type and I'll send you the output
Is there any good documentation available about what situations cause these errors?
BTW, I have checked out a lot of other errors I haven't mentioned and sorted them (unsaved events, etc) but I know the ZMS path is correct, the Apache2 'cgi-bin' module is installed and enabled. I can get a live monitor view of all my monitors from zms. I even checked the contents of the path and found the files nph-zms (link to zms) and zms.
Also, monitors in the montage view are misaligned. In 2-wide and 3-wide, the two working monitors are on opposite sides of the page, on two different rows. In 4-wide they're centred and in 5-wide they're both neatly on the left on one row.
Thanks for any help you can give.
...FAT-zm_monitor.cpp/2324 [Bogus monitor type 'WebSite' for monitor 7]
Socket /var/run/zm/zms-150867s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.
2020-08-18 02:24:47 zmdc 600 ERR 'zma -m 11' exited abnormally, exit status 255 zmdc.pl
2020-08-18 02:24:47 zma_m11 841 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 580
2020-08-18 02:24:46 zms_m11 840 ERR Unable to connect to zmc process for monitor 11 zms.cpp 257
2020-08-18 02:24:46 zms_m11 840 ERR Unable to connect to monitor id 11 for streaming zm_stream.cpp 53
