ALERT - Major UI Changes - Work in Progress
bkjaya1952
Re: ALERT - Major UI Changes - Work in Progress
Post by bkjaya1952 »
We will be happy if you colud release a stable version with these nice modifications . It seems the
latest modification to mysql configuration is not working properly . It is better to release a stable version with the last workable mysql setup
alabamatoy
Post by alabamatoy »
Can we include the monitor add/edit/delete in the collapse at the top of the console? In my experience, adding and deleting monitors is not something one does all the time, so hiding it would recoup some realestate on the console.
alabamatoy
The "cycle" is really nice, except that you cant get out of it. The pulldown for the option to go back to console or montage etc doesnt persist when in cycle mode, so it becomes an aggravating whack-it game to try to get the pulldown to last long enough to hit the console option. Its refreshing so quickly that I couldnt even change the URL to get back that way.
alabamatoy
Seeing some of these:
2021-04-16 13:50:48 web_js 7633 ERR ReferenceError: timeout is not defined zm/cache/skins_classic_js_skin-dark-1618586885.js
alabamatoy
In the monitor / location window...
Probably should remove the second "Longitude" text?
done
