Getting audio recordings to work on zoneminder 1.34.16
user671
Post by user671 » Fri Jul 03, 2020 6:27 am
I posted this topic viewtopic.php?t=29517
and I thought my problem was that on that machine I started with zoneminder 1.32 which didn't support audio and upgraded to 1.34.16 which did support audio recording. I thought maybe something just didn't get upgraded right. I'd been meaning to get do a fresh install so I just reinstalled everything. I started a fresh install of zoneminder from 1.34.16. No upgrade, just a fresh install of 1.34.16. But the audio is not present in zoneminder recordings.
If I listen to my camera in VLC on a random computer in my network, there is audio. I can hear through the camera's microphone. But the camera's audio is not present in the zoneminder recordings.
The fact that I can hear it through VLC tells me the camera's microphones work fine. It has to be a zoneminder issue but I cannot figure out what. I'm wondering if there's just some obvious linux thing I forgot to do on the machine that is running zoneminder.
This machine that is running zoneminder has an AMD RX 470 in it. Do I have to go compile ffmpeg or something to make this work?
Re: Getting audio recordings to work on zoneminder 1.34.16
Post by iconnor » Fri Jul 03, 2020 2:30 pm
There is nothing obvious. As stated before you will have to turn on debugging and share the zmc logs.
Reposting in a different section isn't going to get you different answers.
