I can't seem to be able to make zoneminder use an external drive. Despite having set the ownership and permissions of the directory correctly, it still fails.
Take a look at the attached images.
What am I missing?
Could not open out file: permission denied
- 20200629_181601.jpg (78.92 KiB) Viewed 4222 times
- 20200629_181908.jpg (51.88 KiB) Viewed 4222 times
Re: Could not open out file: permission denied
Need more information about the external drive -- most importantly, is it using a FAT filesystem, or a proper one like ext4? How is it connected (USB, network?) Model number etc. (so others can Google what you've got).
It is possible that the drive is using a FAT file system (which is pretty clueless about permissions and ownership -- no matter what Linux will try and show you) and worse still, doesn't understand symbolic links, which are used by ZoneMinder and a fundamental part of a real filesystem.
The permissions look a bit enthusiastic there - rwxrwxrwx means EVERYONE can look in there, create, edit, delete stuff, which is not great for security, so you may want to tighten that up later.
It's ext4. I chose the lackluster permissions to make sure that the permissions are not the problem. The disk is connected to motherboard SATA. Here's a parted dump:mikb wrote: ↑Tue Jun 30, 2020 3:59 pm Need more information about the external drive -- most importantly, is it using a FAT filesystem, or a proper one like ext4? How is it connected (USB, network?) Model number etc. (so others can Google what you've got).
Model: ATA WDC WD80PURZ-85Y (scsi)
Disk /dev/sdb: 8002GB
Sector size (logical/physical): 512B/4096B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 8002GB 8002GB ext4
Ah, not what I was expecting!
ext4 is a proper file system. Good.
Direct SATA connection -- Good -- this rules out flaky USB enclosures and CIFS/SMB networking devices that don't know how to work properly.
The wide permissions being deliberate I can understand, please make sure to re-attach the doors and windows once you're done testing!
Do I understand correctly that /survaillance (directory ".." from your screenshot) is owned by "server, server" and is therefore only accessible to that user? Could this stop zoneminder traversing into /survaillance to get to the lower directories (zoneminder/events)?
Maybe /survaillance should be rwxr-xr-x (chmod 755) to let ZM look in there? Or try "rwx--x--x" (chmod 711) to let it go in but not look around?
the directories ownership needs to be the same as the web server and Zoneminder user. There are several that need to be the same.
I will try that.mikb wrote: ↑Thu Jul 02, 2020 3:29 pm Ah, not what I was expecting!
Yep that fixed it.
