New install of 1.34.16 and seeing seeing "NaN:NaN:NaNs" when displaying events
jr3us
Post by jr3us » Sun Jun 28, 2020 2:10 pm
As indicated by the subject, I have done a new install using the instructions on raspberry pi os (debian buster for the raspberry pi ) on a raspberry pi 4 with 2 gb
The article below from the zoneminder forum perfectly describes the problem I am having:
viewtopic.php?f=38&t=27729
A comment in the thread from Sabby refers to replacing all the contents from /usr/share/zoneminder from a 1.32.2 archive, but I don't want to go that far.
What version of zoneminder should I go back to IF this is the solution?
Additional information... This happens in firefox, safari, as well as chromium browser.
Regards!
burger
Re: New install of 1.34.16 and seeing seeing "NaN:NaN:NaNs" when displaying events
Post by burger » Tue Jun 30, 2020 5:01 pm
Are you sure you installed correctly? Exactly what install guide did you use? Are there any errors in the logs?
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
jr3us
Post by jr3us » Thu Jul 02, 2020 12:18 pm
I used the following page as a guide to install it:
https://wiki.zoneminder.com/Raspberry_Pi_4_-_Raspbian
When i was configuring the Reolink camera, I initially used the ONVIF method for connecting to the camera. However using onvif was not working well at all with it... corrupting the video as it came into zoneminder. I changed it to use an RTSP connection to the camera and the video corruption went away
note that I do believe the install went sideways for some reason... I did an install on an ECS Liva, and it works fine, so I am going to use the ECS LIVA as the zoneminder server.
Thanks for the assistance!
