Ungraceful shutdown SQL needs rebuilt
Posted: Wed Jun 10, 2020 7:36 pm
Hello all, I had just got 1.35 up and going and my cameras added. I had not done a backup of the zm sql database yet as this was new.
I had an unfortunate issue with a power cable(lost power).
I am definitely not an SQL admin, but can get around.
So now when I try and navigate to ZM_IP/zm I have the following error:
Unable to connect to ZM db.SQLSTATE[HY000] [2002] No such file or directory
CLI:
mysql status
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
service zoneminder status
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2020-06-10 19:33:13 UTC; 5s ago
Process: 3342 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255/EXCEPTION)
sudo myisamchk --silent --force --fast --update-state /var/lib/mysql/*/*.MYI
myisamchk: error: File '/var/lib/mysql/*/*.MYI' doesn't exist
mysql logs:
2020-06-10T19:46:38.792547Z 1 [Warning] [MY-012928] [InnoDB] 4 threads created by InnoDB had not exited at shutdown!
2020-06-10T19:46:39.229584Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.20-0ubuntu0.20.04.1) starting as process 3918
2020-06-10T19:46:39.304769Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2020-06-10T19:46:42.298633Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2020-06-10T19:46:45.697801Z 1 [Warning] [MY-012638] [InnoDB] Retry attempts for reading partial data failed.
2020-06-10T19:46:45.697985Z 1 [ERROR] [MY-012642] [InnoDB] Tried to read 16384 bytes at offset 212992, but was only able to read 0
2020-06-10T19:46:45.698080Z 1 [ERROR] [MY-012592] [InnoDB] Operating system error number 5 in a file operation.
2020-06-10T19:46:45.698175Z 1 [ERROR] [MY-012596] [InnoDB] Error number 5 means 'Input/output error'
2020-06-10T19:46:45.698363Z 1 [ERROR] [MY-012646] [InnoDB] File ./mysql.ibd: 'read' returned OS error 105. Cannot continue operation
2020-06-10T19:46:45.698462Z 1 [ERROR] [MY-012981] [InnoDB] Cannot continue operation.
CLI:
mysql status
mysql logs:
