Filter to trigger external script
rups22
Post by rups22 »
Hi all
I have a problem that's been sending me crazy the last couple of days. I'm totally convinced this is a normal feature to expect with any NVR software so I am sure it's a straight forward fix
I am trying to set up a filter that triggers an external python script when it detects motion immediately
The problem is that the filter is triggering every 10 minutes (seemingly once the event is finished) rather than immediately.
I've attached a screenshot of my setup so far
Thanks in advance
Screenshot 2020-06-05 at 15.12.18.png (86.21 KiB) Viewed 952 times
Re: Filter to trigger external script
Set Options->System->FILTER_EXECUTE_INTERVAL to something smaller.
However filters currently only run on completed events. To change this you need to edit /usr/share/perl5/ZoneMinder/Filter.pm
replace line 324 with line 321 so it looks like
$sql .= ' WHERE ( '.$self->{Sql}.' )';
Please note that you will have to add an EndTime clause to any filters that you want to only act on completed events.
rups22
Post by rups22 »
Awesome thanks will try it out!
