Hello everbody,
I am absolutely new here in the forum and on the topic ZoneMinder. At the beginning I greet you and sorry for my bad English .
First I tell something about my ZoneMinder System. I use a Raspberry Pi Model 4 with a Ubuntu 18.04.4 LTS Server operating system. As a datastore I use my Synology with a NFS share. I linked the complete "/var/cache/zoneminder" directory to my Synology. I use the ZoneMinder version 1.34.7 with a MySQL database and a Apache webserver with SSL only. I use two Vivotek IP cameras FD9367-HV and FD8369A.
I use this thread for my questions. Thank you!
Some questions from a beginner
Hardware: Raspberry Pi 4 Model B 4GB Ram
Software: Ubuntu Server 18.04.4 LTS, ZoneMinder 1.34.7
Monitor-1: Vivotek FD9367-HV, 2MP, H.264 1920x1080 1080p 30FPS
Monitor-2: Vivotek FD8369A-V, 2MP, H.264 1920x1080 1080p 30FPS
Re: Some questions from a beginner
I have a problem with my Monitor-1. I add the Monitor with this options:
General
Source Type: Ffmpeg
Function: Modect
Reference Image Blend: 12,5% (Outdoor)
Source
Source Path: rtsp://user:password@192.168.0.5/live1s1.sdp
Method: TCP
Target colorspace: 32Bit
Capture Resolutions: 1920 x 1080 1080p
In the Console I see the Monitor-1 as green. I can click to it and I see the Camerapicture but I can not click to any links or buttons, the system "hangs". After a while the system hangs I get this errormessage in my browser:
Forbidden
You don't have permission to access this resource.
After a browser refresh I can see the Console without any problems or errors.
General
Source Type: Ffmpeg
Function: Modect
Source
Method: TCP
Forbidden
One way to save events to your NAS is to use systemd mount.
https://wiki.zoneminder.com/Common_Issu ... ive_or_NAS
Since this was written Zoneminder has added additional storage features which also can be used. The systemd mount, however, is reliable. If you want I can try a test from my Pi to my Synology NAS.
Try half the resolution.johnydo wrote: ↑Mon Mar 30, 2020 12:26 pm Hi,
General
Source Type: Ffmpeg
Function: Modect
Source
Method: TCP
Forbidden
Hi,Try half the resolution.
thank you! That solved my problem. Why does this problem arise? Is my system to slow for the 1080p resolution?
EDIT:
When I check top at my Linux system I have only 15% CPU load...
Hi,bbunge wrote: ↑Mon Mar 30, 2020 3:02 pm Hi,
I think my problem is not the NFS share. I have this problem with local disk space also...
