Page 1 of 1
Wansview PTZ?
Posted: Wed Mar 04, 2020 5:16 pm
by opleinew
Has anyone had any luck getting PTZ control working for Wansview cameras? I have a Wansview NCM625GA. Figured someone might have a functional control script and settings already created somewhere. I searched the forums but couldn't find anything conclusive. I did find references to the apis that can trigger movement, and confirmed they work liteblue w/ wget calls but haven't yet figured out how to get those integrated in any useful perl script. Any assistance would be appreciated, otherwise I'll keep digging deeper until I get it running.
Thanks!
Re: Wansview PTZ?
Posted: Wed Mar 04, 2020 11:56 pm
by rockedge
I might have a generic PTZ script you can work with. These are present in /usr/share/perl5/ZoneMinder/Control.
/usr/share/perl5/ZoneMinder/Control/Wanscam.pm
/usr/share/perl5/ZoneMinder/Control/WanscamHW0025.pm
perhaps these can be the templates to a script that will work with Wansview
example: /usr/share/perl5/ZoneMinder/Control/WanscamHW0025.pm
# ZoneMinder Wanscam HW0025 IP Control Protocol Module, $Date: 2009-11-25 09:20:00 +0000 (Wed, 04 Nov 2009) $, $Revision: 0001 $
# Copyright (C) 2001-2015 Florian Neumair
# Modified for use with Foscam FI8918W IP Camera by Dave Harris
# Modified Feb 2011 by Howard Durdle (http://durdl.es/x) to:
#      fix horizontal panning, add presets and IR on/off
#      use Control Device field to pass username and password
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the implementation of the Wanscam HW0025 IP camera control
# protocol
# Known working Devices:
# * Wanscam HW0025
# * IPCC-7210W
package ZoneMinder::Control::WanscamHW0025;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Wanscam HW0025 IP Control Protocol
use Time::HiRes qw( usleep );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub printMsg
	my $self = shift;
	my $msg = shift;
	my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    #print( "http://$address/$cmd\n" );
    my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/$cmd".$self->{Monitor}->{ControlDevice} );
	Info( "http://".$self->{Monitor}->{ControlAddress}."/$cmd".$self->{Monitor}->{ControlDevice} );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub cameraReset
	my $self = shift;
	Debug( "Camera Reset" );
	my $cmd = "reboot.cgi?";
	$self->sendCmd( $cmd );
#Up Arrow
sub moveConUp
	my $self = shift;
	my $params = shift;
	Debug( "Move Up" );
	my $cmd = "decoder_control.cgi?command=0&onestep=1&";
	my $autostop = $self->getParam( $params, 'autostop', 0 );
    if ( $autostop && $self->{Monitor}->{AutoStopTimeout} )
        usleep( $self->{Monitor}->{AutoStopTimeout} );
        $self->moveStop( $params );
#Down Arrow
sub moveConDown
	my $self = shift;
	my $params = shift;
	Debug( "Move Down" );
	my $cmd = "decoder_control.cgi?command=2&onestep=1&";
#Left Arrow
sub moveConLeft
	my $self = shift;
	my $params = shift;
	Debug( "Move Left" );
	my $cmd = "decoder_control.cgi?command=4&onestep=1&";
#Right Arrow
sub moveConRight
	my $self = shift;
	my $params = shift;
	Debug( "Move Right" );
	my $cmd = "decoder_control.cgi?command=6&onestep=1&";
#Diagonally Up Right Arrow
sub moveConUpRight
	my $self = shift;
	my $params = shift;
	my $cmd = "decoder_control.cgi?command=91&onestep=1&";
#Diagonally Down Right Arrow
sub moveConDownRight
	my $self = shift;
	my $params = shift;
	my $cmd = "decoder_control.cgi?command=93&onestep=1&";
#Diagonally Up Left Arrow
sub moveConUpLeft
	my $self = shift;
	my $params = shift;
	my $cmd = "decoder_control.cgi?command=90&onestep=1&";
#Diagonally Down Left Arrow
sub moveConDownLeft
	my $self = shift;
	my $params = shift;
	my $cmd = "decoder_control.cgi?command=92&onestep=1&";
#Stop
sub moveStop
	my $self = shift;
	Debug( "Move Stop" );
	my $cmd = "decoder_control.cgi?command=1&onestep=1&";
#Move Camera to Home Position
sub presetHome
	my $self = shift;
	Debug( "Home Preset" );
	my $cmd = "decoder_control.cgi?command=25&onestep=0&";
# zoom out
sub zoomRelTele
    my $self = shift;
    Debug( "Zoom Tele" );
    my $cmd = "camera_control.cgi?param=17&value=1&";
#zoom in
sub zoomRelWide
    my $self = shift;
    Debug( "Zoom Wide" );
    my $cmd = "camera_control.cgi?param=18&value=1&";
#Set preset
sub presetSet
    my $self = shift;
    my $params = shift;
	my $presetCmd = 30 + (($preset-1)*2);
    Debug( "Set Preset $preset with cmd $presetCmd" );
    my $cmd = "decoder_control.cgi?command=$presetCmd&onestep=0&sit=$presetCmd&";
#Goto preset
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $presetCmd = 31 + (($preset-1)*2);
    Debug( "Goto Preset $preset with cmd $presetCmd" );
#Turn IR on
sub wake
	my $self = shift;
	Debug( "Wake - IR on" );
	my $cmd = "camera_control.cgi?param=14&value=1&";
#Turn IR off
sub sleep
	my $self = shift;
	Debug( "Sleep - IR off" );
	my $cmd = "camera_control.cgi?param=14&value=0&";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
  use ZoneMinder::Control::Wanscam
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, <philip.coombes@zoneminder.com>
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2001-2008  Philip Coombes
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
