ZM not displaying feed
doh
Post by doh » Thu Feb 13, 2020 2:06 pm
I'm running ZM 1.32.3 in a docker container, from the image zoneminderhq/zoneminder:latest-ubuntu18.04
I have a Neos camera running Dafang firmware which is working just fine. I can go into VLC and view the camera feed just fine from my laptop.
However, in ZM I don't get an image at all.
The log file is showing lots of errors as below.
I'm fairly new to ZM, but I think I've configured everything ok. Can anyone shed any light on why it's not working?
(I've tried pulling a new image to upgrade to v1.34, but it doesn't seem like 1.34 is available for docker yet).
2020-02-13 13:59:33.563237 zms_m1[815].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:59:33.523321 zms_m1[815].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:59:33.482570 zms_m1[815].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:59:33.086765 web_js[444].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-142752s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:59:33.022045 web_php[444].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-142752s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:59:32.873033 zms_m1[811].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:59:32.824324 zms_m1[811].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:59:32.780473 zms_m1[811].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:59:32.394335 web_js[444].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-208881s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:59:32.332502 web_php[444].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-208881s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:59:31.960257 zms_m1[806].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:59:31.924444 zms_m1[806].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:59:31.880892 zms_m1[806].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:59:31.473241 web_js[444].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-866486s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:59:31.415789 web_php[444].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-866486s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:59:31.037909 zms_m1[802].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:59:31.001856 zms_m1[802].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:59:30.966102 zms_m1[802].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:59:28.445744 web_js[445].ERR-http://docker.lan:9120/zm/tools/mootools/mootools-more.js/1 [Uncaught TypeError: Cannot read property 'isDisplayed' of undefined]
2020-02-13 13:59:27.485782 web_js[445].ERR-http://docker.lan:9120/zm/tools/mootools/mootools-more.js/1 [Uncaught TypeError: Cannot read property 'isDisplayed' of undefined]
2020-02-13 13:58:55.238080 zmfilter_2[502].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2020-02-13 13:58:55.174450 zmfilter_1[494].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2020-02-13 13:58:34.691730 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:58:34.645160 zmaudit[764].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:58:34.314440 zmdc[764].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:58:34]
2020-02-13 13:58:34.313160 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:58:34, pid = 764]
2020-02-13 13:58:34.265160 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:57:55.194180 zmfilter_2[502].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2020-02-13 13:57:55.124970 zmfilter_1[494].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2020-02-13 13:57:14.322340 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:57:14.274160 zmaudit[714].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:57:14.051750 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:57:14, pid = 714]
2020-02-13 13:57:14.051740 zmdc[714].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:57:14]
2020-02-13 13:57:14.000760 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:56:55.065120 zmfilter_2[502].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2020-02-13 13:56:55.064640 zmfilter_1[494].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2020-02-13 13:56:38.517892 web_js[561].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-803369s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:38.450050 web_php[561].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-803369s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:38.211613 zms_m1[687].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:38.175812 zms_m1[687].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:38.137777 zms_m1[687].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:37.624580 web_js[561].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-443075s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:37.561216 web_php[561].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-443075s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:36.995468 zms_m1[682].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:36.959604 zms_m1[682].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:36.923163 zms_m1[682].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:36.530876 web_js[561].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-997533s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:36.466610 web_php[561].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-997533s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:35.443215 zms_m1[677].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:35.407372 zms_m1[677].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:35.368491 zms_m1[677].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:34.977177 web_js[561].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-458632s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:34.865171 web_php[561].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-458632s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:34.627140 zms_m1[673].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:34.591616 zms_m1[673].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:34.552741 zms_m1[673].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:34.129966 web_js[561].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-766364s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:33.976863 web_php[561].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-766364s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:33.869572 zms_m1[668].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:33.833680 zms_m1[668].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:33.795012 zms_m1[668].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:33.694120 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:56:33.648360 zmaudit[665].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:56:33.298190 zmdc[665].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:56:33]
2020-02-13 13:56:33.298180 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:56:33, pid = 665]
2020-02-13 13:56:33.238110 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:56:33.157308 web_js[442].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-219447s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:33.022415 web_php[442].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-219447s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:32.481972 zms_m1[662].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:32.446339 zms_m1[662].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:32.408175 zms_m1[662].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:32.030877 web_js[442].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-985239s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:31.970286 web_php[442].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-985239s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:31.814830 zms_m1[657].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:31.778961 zms_m1[657].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:31.741421 zms_m1[657].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:31.347603 web_js[442].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-623806s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:31.188804 web_php[442].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-623806s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:30.145652 zms_m1[653].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:30.113710 zms_m1[653].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:30.079109 zms_m1[653].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:29.810969 web_js[569].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-727824s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:29.636289 web_php[569].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-727824s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:28.837855 zms_m1[648].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:28.798123 zms_m1[648].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:28.755742 zms_m1[648].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:28.406361 web_js[593].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-320760s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:28.317636 web_php[593].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-320760s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:27.478567 zms_m1[643].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:27.442757 zms_m1[643].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:27.409040 zms_m1[643].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:27.062796 web_js[593].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-730607s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:26.858607 web_php[593].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-730607s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:26.350184 zms_m1[639].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:26.294289 zms_m1[639].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:26.225695 zms_m1[639].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:25.816772 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-363936s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:25.733771 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-363936s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:25.417364 zms_m1[634].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:25.369571 zms_m1[634].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:25.304028 zms_m1[634].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:25.035367 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-696680s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:24.950281 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-696680s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:24.203671 zms_m1[629].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:24.156005 zms_m1[629].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:24.084965 zms_m1[629].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:23.650706 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-143498s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:23.570164 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-143498s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:23.290694 zms_m1[625].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:23.239086 zms_m1[625].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:23.187737 zms_m1[625].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:22.781119 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-179000s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:22.715514 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-179000s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:21.919052 zms_m1[620].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:21.787130 zms_m1[620].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:21.695886 zms_m1[620].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:21.297616 web_js[443].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-196619s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:21.135331 web_php[443].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-196619s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:20.989995 zms_m1[616].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:20.943355 zms_m1[616].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:20.903592 zms_m1[616].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:20.586479 web_js[443].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-393657s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:20.520129 web_php[443].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-393657s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:20.033260 zms_m1[611].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:19.994578 zms_m1[611].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:19.950375 zms_m1[611].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:19.446411 web_js[443].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-984816s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:19.383364 web_php[444].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-984816s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:18.603142 zms_m1[607].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:18.571223 zms_m1[607].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:18.529212 zms_m1[607].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:18.096992 web_js[442].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-149613s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:18.022990 web_php[446].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-149613s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:17.853308 zms_m1[602].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:17.817366 zms_m1[602].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:17.779079 zms_m1[602].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:17.369851 web_js[446].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-230945s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:17.301548 web_php[446].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-230945s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:16.724709 zms_m1[598].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:16.684848 zms_m1[598].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:16.642592 zms_m1[598].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:16.289070 web_js[446].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-518857s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:16.216333 web_php[446].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-518857s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:15.401224 zms_m1[592].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:15.361390 zms_m1[592].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:15.318227 zms_m1[592].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:14.708305 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-155758s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:14.650109 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-155758s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:13.635020 zms_m1[587].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:13.603134 zms_m1[587].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:13.568718 zms_m1[587].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:13.473900 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:56:13.433540 zmaudit[582].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:56:13.107141 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-316593s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:13.053410 zmdc[582].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:56:13]
2020-02-13 13:56:13.053300 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:56:13, pid = 582]
2020-02-13 13:56:13.037902 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-316593s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:13.007510 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:56:12.231262 zms_m1[581].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:12.194177 zms_m1[581].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:12.151173 zms_m1[581].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:11.782390 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-304285s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:11.721901 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-304285s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:11.449832 zms_m1[576].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:11.402073 zms_m1[576].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:11.364654 zms_m1[576].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:10.950228 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-915970s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:10.892318 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-915970s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:10.112916 zms_m1[571].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:10.077078 zms_m1[571].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:10.041869 zms_m1[571].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:09.609921 web_js[445].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-257924s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:09.556810 web_php[445].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-257924s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:08.686451 zms_m1[566].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:08.654638 zms_m1[566].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:08.611481 zms_m1[566].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:08.243513 web_js[444].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-014767s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2020-02-13 13:56:08.159544 web_php[444].ERR-/usr/share/zoneminder/www/includes/functions.php/2048 [Socket /var/run/zm/zms-014767s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2020-02-13 13:56:08.036888 zms_m1[560].ERR-zms.cpp/254 [Unable to connect to zmc process for monitor 1]
2020-02-13 13:56:08.000714 zms_m1[560].ERR-zm_stream.cpp/48 [Unable to connect to monitor id 1 for streaming]
2020-02-13 13:56:07.962526 zms_m1[560].ERR-zm_monitor.cpp/538 [Got empty memory map file size 0, is the zmc process for this monitor running?]
2020-02-13 13:56:07.243960 zmtelemetry[535].INF-zmtelemetry.pl [Telemetry data uploaded successfully.]
2020-02-13 13:56:01.614270 zmtelemetry[535].INF-zmtelemetry.pl [Sending data to ZoneMinder Telemetry server.]
2020-02-13 13:56:01.231720 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:56:01.182740 zmaudit[550].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:56:00.942080 zmdc[550].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:56:00]
2020-02-13 13:56:00.942070 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:56:00, pid = 550]
2020-02-13 13:56:00.902120 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:55:56.151800 zmstats[544].INF-zmstats.pl [Stats Daemon starting in 30 seconds]
2020-02-13 13:55:55.850840 zmdc[544].INF-zmdc.pl ['zmstats.pl' started at 20/02/13 13:55:55]
2020-02-13 13:55:55.850760 zmdc[465].INF-zmdc.pl ['zmstats.pl' starting at 20/02/13 13:55:55, pid = 544]
2020-02-13 13:55:55.675540 zmdc[465].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-02-13 13:55:55.612550 zmaudit[533].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 505. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-02-13 13:55:55.514770 zmdc[535].INF-zmdc.pl ['zmtelemetry.pl' started at 20/02/13 13:55:55]
2020-02-13 13:55:55.514750 zmdc[465].INF-zmdc.pl ['zmtelemetry.pl' starting at 20/02/13 13:55:55, pid = 535]
2020-02-13 13:55:55.260410 zmdc[533].INF-zmdc.pl ['zmaudit.pl -c' started at 20/02/13 13:55:55]
2020-02-13 13:55:55.258990 zmdc[465].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/02/13 13:55:55, pid = 533]
2020-02-13 13:55:55.213800 zmdc[465].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-02-13 13:55:55.130490 zmdc[528].INF-zmdc.pl ['zmupdate.pl -c' started at 20/02/13 13:55:55]
2020-02-13 13:55:55.130480 zmdc[465].INF-zmdc.pl ['zmupdate.pl -c' starting at 20/02/13 13:55:55, pid = 528]
2020-02-13 13:55:55.129190 zmwatch[517].INF-zmwatch.pl [Watchdog starting, pausing for 30 seconds]
2020-02-13 13:55:55.013410 zmfilter_2[502].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
docker-compose:
  zoneminder:
    container_name: zoneminder
    image: zoneminderhq/zoneminder:latest-ubuntu18.04
    restart: unless-stopped
    ports:
      - 9120:80
    network_mode: "bridge"
    privileged: true
    shm_size: 512M
    environment:
      - TZ=${TZ}
      - PUID=${PUID}
      - PGID=${PGID}
    volumes:
      - zm_events:/var/cache/zoneminder/events
      - zm_images:/var/cache/zoneminder/images
      - zm_logs:/var/cache/zoneminder/logs
      - zm_mysql:/var/cache/zoneminder/mysql
Re: ZM not displaying feed
Post by bbunge » Fri Feb 14, 2020 12:48 pm
If it works in VLC it will work in Zoneminder. Use ffmpeg and the same string used in VLC. Also use VLC to check the camera resolution. It is likely different than advertised and needs to be exact in Zoneminder!
doh
Post by doh » Fri Feb 14, 2020 1:02 pm
So, looks like there's an issue with that zoneminder image. I've tried the one on the ZM WIki and it now works fine. Thanks
