/etc/zm/secrets.ini is missing
rookie7799
Post by rookie7799 » Sun Jan 26, 2020 10:04 pm
Howdy!
Just installed zoneminder with all prereqs etc and everything works great. Decided to give zmeventnotification a try and when starting it looks for "/etc/zm/secrets.ini" which I don't even have.
Tried searching for ZM docs / wiki and there is nothing on that file. I do have /etc/zm/ dir:
tree /etc/zm/
/etc/zm/
├── conf.d
│   ├── 01-system-paths.conf
│   ├── 02-multiserver.conf
│   └── README
└── zm.conf
Any ideas?
Thank you!
asker
Re: /etc/zm/secrets.ini is missing
Post by asker » Sun Jan 26, 2020 10:35 pm
You need to follow the ES install guide at https://zmeventnotification.readthedocs.io/en/stable/
If you used install.sh to install, it would copy a sample secrets.ini file
rookie7799
Post by rookie7799 » Sun Jan 26, 2020 11:47 pm
Got it! Thank you!
Btw, I was following that guide but the "Making sure everything is running (in manual mode)" is before the running the install.sh part so it's a bit confusing because install.sh would actually copy that file.
All good now, thanx again!
rakali
Post by rakali » Sat Feb 15, 2020 6:53 am
had to search for this one too.
