Page 1 of 1
ZOneminder suddenly stopped working
Posted: Sun Dec 15, 2019 8:23 am
by Guaro
Hi
Recently I acquired two cameras (reolink rlc-420-5mp), I decided to use zoneminder although I am new to this topic, I can install and it worked but shortly after it stopped working. Here I leave zoneminder events
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Server.php on line 80
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Server.php on line 137
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Storage.php on line 75
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Group.php on line 50
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Monitor.php on line 271
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Monitor.php on line 273
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Monitor.php on line 321
Deprecated: Array and string offset access syntax with curly braces is deprecated in /srv/zoneminder/www/includes/Monitor.php on line 331
zoneminder.service - ZoneMinder - CCTV Monitoring and Recording System
     Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; vendor preset: disabled)
     Active: active (running) since Sun 2019-12-15 02:26:17 -05; 36min ago
   Main PID: 2834 (zmdc.pl)
      Tasks: 7 (limit: 28769)
     Memory: 154.1M
     CGroup: /system.slice/zoneminder.service
             ├─2834 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
             ├─2859 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
             ├─2863 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
             ├─2885 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
             ├─2908 /usr/bin/perl -wT /usr/bin/zmwatch.pl
             ├─2931 /usr/bin/perl -w /usr/bin/zmupdate.pl -c
             └─2934 /usr/bin/perl -wT /usr/bin/zmstats.pl
Dec 15 02:58:18 carambox zmfilter_1[2859]: INF [Checking filter PurgeWhenFull delete returned 0 events ]
Dec 15 02:58:18 carambox zmfilter_2[2863]: INF [Checking filter Update DiskSpace update disk space returned 0 events ]
Dec 15 02:59:18 carambox zmfilter_1[2859]: INF [Checking filter PurgeWhenFull delete returned 0 events ]
Dec 15 02:59:18 carambox zmfilter_2[2863]: INF [Checking filter Update DiskSpace update disk space returned 0 events ]
Dec 15 03:00:18 carambox zmfilter_1[2859]: INF [Checking filter PurgeWhenFull delete returned 0 events ]
Dec 15 03:00:18 carambox zmfilter_2[2863]: INF [Checking filter Update DiskSpace update disk space returned 0 events ]
Dec 15 03:01:18 carambox zmfilter_1[2859]: INF [Checking filter PurgeWhenFull delete returned 0 events ]
Dec 15 03:01:18 carambox zmfilter_2[2863]: INF [Checking filter Update DiskSpace update disk space returned 0 events ]
Dec 15 03:02:18 carambox zmfilter_1[2859]: INF [Checking filter PurgeWhenFull delete returned 0 events ]
Dec 15 03:02:18 carambox zmfilter_2[2863]: INF [Checking filter Update DiskSpace update disk space returned 0 events ]
I'm using Archlinux
thanks
Re: ZOneminder suddenly stopped working
Posted: Mon Dec 16, 2019 12:08 am
by snake
Post full logs. Turn debugging on.
If the system is resource constrained, lower the frame rate / resolution on the cameras.
Posted: Mon Dec 16, 2019 1:59 am
by iconnor
I recently fixed those issues.
Please upgrade.
Posted: Mon Dec 16, 2019 8:50 am
by Guaro
Hi
I made a mistake when posting my problem since I have version 1.32.3, so I don't know if it is correct to follow the solution in this forum or close and publish in the forum 1.32.
Regarding the resources of the PC, I think it is still enough despite being an old PC. The PC has 32GB RAM and an XEON E5-2680.
Thank you for the quick response.
