Unable to open input rtsp
famp
Post by famp »
Hi, I have an IP camera that works from vlc with the following address rtsp: // user: passs @ xxxx: 555 / onvif1 and since zm does not show image this is the type of error Unable to open input rtsp: // user: pass @xxxx: 555 / onvif1 due to: Operation now in progress zm_ffmpeg_camera.cpp the camera is external to the zoneminder network
tcp connection to udp cambiano without success.
vlc resolution 1280 * 720 inserted in zm without success
color 32 24 and gray without success.
Blue screen.
snake
Re: Unable to open input rtsp
Post by snake »
Can you access the video from the server terminal via ffmpeg?
ffmpeg -i rtsp: // user: passs @ xxxx: 555 / onvif1 output.mp4
sounds like a networking issue.
1.30 is old. We were incorrectly applying the error code to error message.
Long story short: UPGRADE and then we can talk.
We are now at 1.33.15.
