Event playback plays 1 frame then white
Tomm
Post by Tomm »
On 1 camera out of 4 i get this :
The first frame displays normally, then the playback goes white.
The frames are present in storage, i can see them when clicking on the Frames or Stills buttons.
I can also see them stored on the hard drive.
Any insights please ?
Thx,
Tom.
kitkat
Re: Event playback plays 1 frame then white
Post by kitkat »
It looks like there are errors in your log - If you copy and post them then someone may be able to help :)
Tomm
Post by Tomm »
the errors are unrelated i think :
2019-10-13 21:39:54	zmu		13092	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	538
2019-10-13 21:39:54	zmu		13092	ERR	Can't connect to capture daemon: 5 Monitor-5	zmu.cpp	474
Those errors must be for a camera which I've set to None function, and also set to Disabled.
Also:
* export Video works just fine,
* other cams work just fine.
