ImageBufferCount is too small. Needs to be at least XX
mflorezm
Post by mflorezm »
I'm using some M3204 and one P3344 axis cameras thru onvif profile. The cameras are working at 800x600 resolution, 2 FPS, H.264.
The ZM server is working with FFmpeg, 800 x 600 res, 24 bits, but No matter what i tried, the log always shows me ImageBufferCount is too small. Needs to be at least XX. Either increase it or decrease time between keyframes.
I have changed the default Image Buffer Size (frames) from 20 to 21, 65, etc and always we have the same warning.
Axis don't have a keyframe interval parameter, so, i read on google, that it is better to duplicate the FPS on the GOV parameter, but it did not work too.
Does anybody know what right value should i set on axis to pass the FFMPEG analisis warning?
I have enough memory (~# df -h|grep "Filesystem\|shm")
Filesystem Size Used Avail Use% Mounted on
tmpfs 1006M 216M 791M 22% /dev/shm
All help will be appreciated.
Thanks,
MFM
Re: ImageBufferCount is too small. Needs to be at least XX
Just keep increasing it until the messages go away.
The message is generated when we find that it has been too long since the last keyframe.
