ZM 1.32.3 - Unable to receive frame
go0die
Post by go0die » Tue Aug 13, 2019 2:17 pm
From yesterday one of my cams started to warn me with log: "Unable to receive frame 11250: Resource temporarily unavailable, continuing". Also all of cameras work correctly on 20 fps setting, except this problem cam. But it worked properly before yesterday.
What does it mean and how to find solution?
And quick question: Events on this camera record rotated, but for stream picture is good. Where to dig?
PS! Maximum FPS and Alarm FPS settings are blank and already tried to reinstall ZM completely, nothing changes.
operat0r
Re: ZM 1.32.3 - Unable to receive frame
Post by operat0r » Tue Aug 13, 2019 5:05 pm
* powercycle the server
* powercycle the cam
* disable the existing source and recreate the source
* swap the sources IP's with working ones
* swap the actual cams working ones
* plug the cam into a known good port with new cable to test
Post by bbunge » Tue Aug 13, 2019 6:32 pm
Linux distro and version? Info on your hardware? Check /dev/shm for free space? Camera settings?
