Repository of DB entries
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
liderbug
Post by liderbug » Tue Aug 06, 2019 4:55 pm
I'm trying to get ZM working on a RasPi w cam. - but that's a aside - sort of...
Google is a bit here, a bit there, some good, some bad and 26 different ways to install and 1200 different ways to configure a camera.
What is needed is a ZM.com page where you select your OS, which will then offer a select (if needed) version, which will .....
all leading to a contributed set of "INSERT/UPDATE" sql lines.
IE. see: https://www.nvidia.com/Download/index.aspx
NOW THEN: I need a INSERT into Monitor for a RasPi 3B+, Buster, local, /dev/video0 (std ras cam), but what da "L" do I use for Device Format, Capture Palette and several other items.
There, I've tooted. Yawl have a good day.
Users browsing this forum: No registered users and 8 guests
