API not working after install on fresh Buster system
jake1164
Post by jake1164 » Fri Jul 12, 2019 11:37 am
I did a fresh Debian 10 (Buster) install following the posted instructions.
Upon restarting apache and before doing anything else ZM is running, logs are green, however when you navigate to :
http://ip/zm/api/host/getVersion.json results in a Not Found page.
The API directory (/usr/share/zoneminder/www/api) has the following files / folders:
app build.properties build.xml composer.json CONTRIBUTING.md index.php lib README.md
Note that the host folder is missing.
Navigating to http://ip/zm/api/ results in the following CakePHP error:
URL rewriting is not properly configured on your server. 1) Help me configure it 2) I don't / can't use URL rewriting
I followed the instructions a second time on a fresh VM and had the same results.
I have found a few fragments of other issues with buster api's but no definitive resolution.
Re: API not working after install on fresh Buster system
Post by bbunge » Fri Jul 12, 2019 8:39 pm
I must admit that I did not check the API as I seldom use anything other than a web browser. Will try to find time to load up Debian again and see what I can find.
JoshZ17
Post by JoshZ17 » Sat Jul 13, 2019 2:07 am
I'm having the same issue. Fresh install of Buster.
Post by bbunge » Sat Jul 13, 2019 2:26 am
Looks like all the files installed with correct permissions. Cake reports rewrite not working. Looking into Apache config. Seems sim to issues we had with Ubuntu 17.10.
Will continue in the morning...old guys need sleep, too.
girkers
Post by girkers » Sat Jul 13, 2019 10:01 am
I spent a day trying buster without success and I ended up using CentOS instead.
logicos94
Post by logicos94 » Sat Jul 13, 2019 10:53 am
Some issues too in https/http support:
I noticed this:
var monitorUrl = 'https://zm.eez.fr:80/zm/index.php';
My server is behind a "nginx/proxy" with "https" protocol.
But local http Apache server listen on port "80" with "http" protocol.
"SetEnv HTTPS on" is present in my "VirtualHost" configuration.
":80" is irrelevent here.
If I remove this , It's work like expected.
Regards,
Post by bbunge » Sat Jul 13, 2019 12:21 pm
I noticed this:
Regards,
But does your api work?
Post by bbunge » Sat Jul 13, 2019 1:31 pm
There are some .htaccess files missing from the /usr/share/zoneminder/api directories. This may be the key to the API not working. May take me some time to figure this out as Saturday chores take preference...
sammyke007
Post by sammyke007 » Mon Jul 15, 2019 11:19 am
Same here, fresh Debian 10 (Buster) installation and API's not working.
Chimaera
Post by Chimaera » Mon Jul 15, 2019 11:28 am
This is the answer, you need to add the following code to .htaccess in 3 places
/usr/share/zoneminder/www/api/app
/usr/share/zoneminder/www/api/app/webroot
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /zm/api
</IfModule>
sammyke007
Post by sammyke007 » Mon Jul 15, 2019 11:37 am
Tnx Chimaera! ZMNinja is connected!
Zoneminder + ZMNinja working fine now on an old Dell Optiplex 780 SFF running Debian 10!
jake1164
Post by jake1164 » Tue Jul 16, 2019 11:13 pm
Thanks! Now I can get my wife off my back about how I broke the cameras. :)
Users browsing this forum: Eiserfeyer and 2 guests
