How to disable PTZ motion detection durning camera movement
go0die
Post by go0die » Thu Jul 11, 2019 2:15 pm
Started with ZM and now time came to use HikVision PTZ camera. I can move cam from ZM and make some presets, but the question is:
As I need to use motion detection, is it possible to disable PTZ motion detection durning camera movement?
Re: How to disable PTZ motion detection durning camera movement
Post by rockedge » Thu Jul 11, 2019 4:15 pm
there could be a round about way to do it by using "run states" and set up 2 different monitors using the same camera....
monitor 1 has no PTZ control and does have motion detection active
monitor 2 has PTZ but motion detection turned off.
save a run state that has camera 1 set to "modect" and camera 2 "none"
then save a run state that has camera 1 set top "none" and camera 2 set to monitor so you can move it.
choose by selecting which run state ZM is operating under
only an idea..may work for you
go0die
Post by go0die » Mon Jul 15, 2019 6:12 am
Thank you for reply!
I will test it some day and write here results.
go0die
Post by go0die » Mon Jul 15, 2019 6:21 am
But problem is, that I need to use some assets when and where camera moves by itself, so I need better solution.
