ZM on Fedora 30?
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
kenworth
ZM on Fedora 30?
Post by kenworth » Thu May 30, 2019 12:36 pm
Is anyone successfully running ZM on Fedora 30? Would appreciate knowing before I attempt an upgrade. I'm currently on Fedora 28 running ZM 1.32.3-1.fc28.
kenworth
Re: ZM on Fedora 30?
Post by kenworth » Wed Jun 05, 2019 11:07 am
Never got any replies so I bit the bullet and upgraded. Went perfectly fine and took about an hour. Zoneminder appears to be functioning perfectly and I haven't found any other problems at this point.
liderbug
Post by liderbug » Thu Jul 11, 2019 3:50 pm
I'm in the same place - just spent an hr - you don't have... ok, now I do. you don't have... ok, now you don't have crud.
What steps did you do to get it running? Thanks
PS to ZM why isn't it in the fedora repo?
kenworth
Post by kenworth » Tue Jul 16, 2019 6:46 pm
I just ran the standard upgrade from Fedora 28 to 30 process. I'm getting the packages from the rpmfusion-free repo:
zoneminder.x86_64 1.32.3-3.fc30 @rpmfusion-free
zoneminder-common.x86_64 1.32.3-3.fc30 @rpmfusion-free
zoneminder-httpd.x86_64 1.32.3-3.fc30 @rpmfusion-free
Post upgrade everything just worked.
apti
Re: ZM on Fedora 30? STUCK ON 29
Post by apti » Tue Jul 23, 2019 11:31 pm
No Go here. upgrade from fedora 29 to fedora 30 fails because it can't find the zoneminder repo for fedora 30. I looked manually and it is not there. only up to 29 so looks like we have to wait until ZM puts up a repo for fedora 30.
