Login denied for user "admin"
banzaay
Post by banzaay » Sun Apr 07, 2019 8:07 am
Hi all,
I have enabled authentication and with the standard USER/PASSWORD it works fine.
When I change the password to a new one the following error appear in my log:
The complete line is:
2019-04-07 10:05:39 web_php 5659 WAR Login denied for user "admin" /usr/share/zoneminder/www/includes/auth.php 58
How can avoid this ?
Re: Login denied for user "admin"
Post by rockedge » Sun Apr 07, 2019 5:08 pm
where did you enable ZM auth? how did you change the admin password?
banzaay
Post by banzaay » Mon Apr 08, 2019 1:01 pm
I have done both activities from the web console.
srinivas
Post by srinivas » Sat Apr 13, 2019 6:08 am
I've been experiencing the same issue.
banzaay
Post by banzaay » Fri Apr 19, 2019 4:03 pm
I have found another strange behaviour, if I try to download an export of logs from the web page I get an Internal Server Error (500).
banzaay
Post by banzaay » Fri May 17, 2019 7:06 am
I have restarted the server many times, but the problem still persist.
Then last night after a black out and restart of the server the problem disappear.
Strange ....
Post by rockedge » Mon May 20, 2019 12:32 am
before the blackout forced a complete restart of the system did you restart Apache at any point after the installation of zoneminder?
I am wondering if the restart of ZM might have done it.
all of this is speculation because I have no idea what operating system and version is,nor do I know what web server or PHP version you are dealing with. Basically saying that knowing more information on the specifics of your setup would help
banzaay
Post by banzaay » Mon May 20, 2019 7:39 am
I have restarted the server 5 or 6 times to install Ubuntu package upgrade.
I'm using Apache and PHP provided from the standard repository of Ubuntu 19.04.
