has anyone tried any of these new cameras built into led light bulbs with 360 Panoramic views that have speaker / mic and have a motion detector? this sounds like a great door or hallway cam.
They mention no ports for router and cloud alot. The descriptions usually mention not compatible without IE or chrome. so I wounder has anyone wiresharked or tcpdumped this to see if it is able to be supported on zoneminder..
https://www.ebay.ca/itm/360-Mini-Securi ... :rk:8:pf:0
https://www.aliexpress.com/w/wholesale- ... eedQuery=n
these look pretty cool. be nice if motion would trigger alarm on zoneminder and if they can be made to work and block cloud
Ebay light bulb 360 1080p android compatible
Re: Ebay light bulb 360 1080p android compatible
ZM is definitely going to need a de-fisheye filter for that...
has anyone done anything with theses yet?
You may be looking at something different, but the ones I bought a couple years ago died before I could figure out how to access them in ZM...
The light they put out was pretty lame, too.
