Call to undefined function apc_fetch()
ICXC_Nika
Post by ICXC_Nika » Mon Feb 11, 2019 8:26 pm
For the past year I have had Ubuntu 16.04 running ZM 1.30.2. Finally getting tired of the ZM Update popups I updated to Ubuntu 18.04.1 LTS and ZM 1.33.1. It ran fine over the weekend and I can view events from the 10 monitors setup but there are several features in the Web UI that are not working for me. This led me to test PHP and I get:
Fatal error: Uncaught Error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php:91 Stack trace: #0 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(363): ApcEngine->read('myapp_cake_core...') #1 /usr/share/zoneminder/www/api/lib/Cake/I18n/I18n.php(235): Cache::read('cake_dev_en-us', '_cake_core_') #2 /usr/share/zoneminder/www/api/lib/Cake/basics.php(636): I18n::translate('Cache engine "%...', NULL, 'cake_dev') #3 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(184): __d('cake_dev', 'Cache engine "%...', '_cake_core_') #4 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine('_cake_core_') #5 /usr/share/zoneminder/www/api/app/Config/core.php(375): Cache::config('_cake_core_', Array) #6 /usr/share/zoneminder/www/api/lib/Cake/Core/Configure.php(72): include('/usr/share/zone...') #7 /usr/share/zoneminder/www/api/lib/Cake/bootstrap.php(442): Configure::bootstrap(true) #8 /usr/share/zoneminder/www/api/app/webroot/index.php(90): incl in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php on line 91
I have gone through several suggestions within posts here but with my non-existent *nix knowledge, I thought I could use some hand holding on this before I make it worse.
Thank you,
Todd
Thank you,
Todd
ZM 1.30.2.
Ubuntu 16.04
iconner package
Re: Call to undefined function apc_fetch()
Post by knight-of-ni » Mon Feb 11, 2019 11:11 pm
You are either missing the apcu package and/or the apcu_bc package (package names can vary), or apcu cache is not enabled in your php.ini.
ICXC_Nika
Post by ICXC_Nika » Tue Feb 12, 2019 5:31 am
Thank you worthy Knight of Ni! I have both packages so I will look at the ini. If it works I shall bring you a shrubbery.
Thank you,
Todd
ZM 1.30.2.
Ubuntu 16.04
iconner package
Post by knight-of-ni » Tue Feb 12, 2019 1:23 pm
Since you are running Ubuntu, you need to be careful to edit the correct php.ini file. I don't recall which one off the top of head, but it should be in the documentation.
ICXC_Nika
Post by ICXC_Nika » Tue Feb 12, 2019 4:40 pm
Thank you! I can only find two php.ini files each for 7.0 and 7.2, none of which make mention of APCU.
I should also mention that the features that do not work in IE, like Add monitor button and rename event, do work in Chrome but Chrome does not show the image.
find / -type f -name "php.ini"
/etc/php/7.0/apache2/php.ini
/etc/php/7.0/cli/php.ini
/etc/php/7.2/apache2/php.ini
/etc/php/7.2/cli/php.ini
php-apcu is already the newest version (5.1.9+4.0.11-1build1)
php-apcu-bc is already the newest version (1.0.3-2xenial2)
Is it of consequence that my php-apcu-bc denotes Xenial and my OS is now Bionic?
Which Docs will I be able to find the apcu Cache described?
Thank you,
Todd
ZM 1.30.2.
Ubuntu 16.04
iconner package
asker
Post by asker » Tue Feb 12, 2019 6:29 pm
Incidentally, I spent a few hours struggling with apc_fetch() foo when I updated to Ubuntu 18. I installed everything many times and only later realized my CLI PHP was 7.2 but Apache was using 7.0. So I had to do a a2dismod php7.0 and a2enmod php7.2 and voila.
ICXC_Nika
Post by ICXC_Nika » Wed Feb 13, 2019 3:28 am
Thank you Asker! I will take a look at it in the AM.
Todd
Thank you,
Todd
ZM 1.30.2.
Ubuntu 16.04
iconner package
