Pressing the "add" button, to add a monitor/camera does not work?
glenngould
Post by glenngould »
I'm using ZM 1.32.3 on Freenas 11.2...all fresh install (coming from Rockstor) and having the following problem.
I can get into the GUI of ZM and all its menu's BUT if I want to add a camera/monitor by pressing the "ADD" button (see attachment) no pop-up or new menu is showing up in order to enter IP, PW or User. I've tried IE and Chrome, no change in case the browser has an impact.
Do you have any idea where to start to investigate or how to resolve this issue :?:
Many thanks for your help-regards,
Roland
Re: Pressing the "add" button, to add a monitor/camera does not work?
there are big javascript problems here.
I suspect an issue with the apache config not being updated to include the /cache alias.
n8klayko
Post by n8klayko »
Any further updates on this issue? I am having the same issue and really want to get ZM setup and working in my FreeNas machine via the plugin.
