Logging Configuration
jsylvia007
Post by jsylvia007 »
Morning All!
Currently, I have my logging configured as follows:
LOG_LEVEL_SYSLOG = Warning
LOG_LEVEL_FILE = None
LOG_LEVEL_WEBLOG = None
LOG_LEVEL_DATABASE = Info
LOG_DATABASE_LIMIT = 500000
This basically fills the database with a bunch of informational logs, that most of the time are of little use (to be in the database).
I'm thinking that I want to do this:
LOG_LEVEL_FILE = Info
LOG_LEVEL_DATABASE = Warning
LOG_DATABASE_LIMIT = 50000   ##(factor of 10x less than above, because it's only WARNINGS and higher).
What does everyone else have their logging stuff set to? Is there a recommendation? If people do use files for their logs, is the logrotate configuration sufficient?
Re: Logging Configuration
Mine is something like the following.
I log Warnings and up to Syslog so that logcheck will email anything weird to me.
FILE = Debug because I am a developer and have debug turned on all the time.
WEBLOG generally only breaks things.
Database logging is not well designed and you really don't want to fill it up too much.
LOG_LEVEL_FILE = Debug
jsylvia007
iconnor wrote: Tue Dec 11, 2018 2:34 pm Mine is something like the following.
Thanks man! I think I will mirror pretty much what you have, except keep the FILE at "INFO", and limit the database to 50000.
alabamatoy
Post by alabamatoy »
Every now and then, one of my cameras will hiccup and I will get thousands of log entries in the span of a few minutes about buffer overflow. I have a script which watches syslog for this, and if it finds more than some preset thresholds in a given span of time, it throws a semaphore and checks it every 10 minutes. If after 30 minutes the warnings persist, it will restart ZM. My question is, can someone help me with the logcheck ignore statement/file for these buffer overlow log entries? They look like
Dec 17 22:32:40 zm_server_name zmc_m4[7014]: WAR [Buffer overrun at index 23, image 123, slow down capture, speed up analysis or increase ring buffer size]
So I am looking to make logcheck ignore "WAR [Buffer overrun at index" entries. Logcheck sends me output from my log watcher script, so I know if these warnings are there, but I dont want logcheck files emailed to me that have thousands of lines of these warnings. Any suggestions?
