[SOLVED] Live View not working due to missing socket
zmeggyesi
Post by zmeggyesi » Mon Sep 24, 2018 6:25 am
Hi All,
I've recently installed ZoneMinder by building it via packpack (since the Raspbian/Debian packages are still on 1.30), following the docs here: https://zoneminder.readthedocs.io/en/la ... kpack.html
I managed to link up two TP-Link NC450 cameras (that were linked up previously too), and I get a green source, with seemingly recording going on, but for the life of me I cannot figure out why Live View is not working.
The Chrome DevTool displays a stream of errors saying
getStreamCmdResponse stream error: Socket /var/run/zm/zms-127723s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.
, but if I'm running watch -n 1 ls -lah /var/run/zm, I can see the socket being created then destroyed, while .lock files fill up the directory.
The configs are mostly defaults, I only changed the ZMS path from nph-zms to zms only, but as far as I can tell, Apache ScriptAlias directives don't overlap (what I've seen to be a common cause based on Github issues and forum posts), and the paths are otherwise good.
Can anyone lend me a hand with this?
Re: Live View not working due to missing socket
Post by knight-of-ni » Mon Sep 24, 2018 1:56 pm
Changing nph-zms to zms is guaranteed to break things. Yes, it's a symlink, but zms behaves differently when called by a different name.
Since you used the build system, we know what your PATH_ZMS should be. See:
https://github.com/ZoneMinder/zoneminde ... /rules#L28
It needs to match that, exactly, w/o the quotes or any extra whitespace following it.
Post by knight-of-ni » Mon Sep 24, 2018 2:07 pm
Once you fix path_zms, if that still does not fix things, can you post your zoneminder apache config?
I'm looking at the apache config in the debian build folder, and it looks suspiciously too simple:
https://github.com/ZoneMinder/zoneminde ... pache.conf
If yours matches that, make a backup of it, then replace it with the one that ships with Ubuntu:
https://github.com/ZoneMinder/zoneminde ... inder.conf
None of us develop on Debian, so this might very well be a case of your particular build needing some love.
We might very well need someone to be a temporary guinea pig to get it right for Debian builds.
zmeggyesi
Post by zmeggyesi » Mon Sep 24, 2018 5:45 pm
Thanks for the tips. I'll make the changes tomorrow (once I'm back on one subnet with the box), and let you know if either option worked.
As it stands, I'd be willing to run a few tests on said box, if they're not time-critical, and let you know how things work out. I would need some sort of guide as to how to run those tests, though.
zmeggyesi
Post by zmeggyesi » Tue Sep 25, 2018 4:16 am
I reset the ZMS path, but apparently, the Apache config was already the Ubuntu version, introduced by the build system - so at least that's good.
The error still persists, though.
I notice a repeated line through the log:
zmc_m3		11860	WAR	libjpeg-turbo is required for reading a JPEG directly into a RGB32 buffer, reading into a RGB24 buffer instead.	zm_image.cpp	1148
This is only warning-level, not an error, so it might not be related, but since libjpeg-turbo is already installed according to apt-cache, it's strange nonetheless.
root@observer:/etc/apache2/conf-enabled# apt-cache policy libjpeg62-turbo
libjpeg62-turbo:
  Installed: 1:1.5.1-2
  Candidate: 1:1.5.1-2
  Version table:
 *** 1:1.5.1-2 500
        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
        100 /var/lib/dpkg/status
But let's deal with one problem at a time...
zoneminder.conf.txt
TXT extension only to allow uploading
(1.61 KiB) Downloaded 60 times
zmeggyesi
Post by zmeggyesi » Thu Sep 27, 2018 11:12 am
So it turns out that this line
WAR [zmc_m4] [libjpeg-turbo is required for reading a JPEG directly into a RGB32 buffer, reading into a RGB24 buffer instead.]
is not a warning. It seems to be, in fact a fatal error, and once I set the color space to 24-bit to get around this (despite libjpeg-turbo being installed), the Live view started working just fine.
Re: [SOLVED] Live View not working due to missing socket
Post by knight-of-ni » Thu Sep 27, 2018 12:16 pm
This is strange. This is one of those things that we though was done and settled years ago.
In Debian packaging, the control file contains the list of build dependencies:
https://github.com/ZoneMinder/zoneminde ... an/control
Looking at that, it is missing the libjpeg-turbo package. I'd expect a line like the one in the Ubuntu control file:
https://github.com/ZoneMinder/zoneminde ... ontrol#L20
First, make sure a libjpeg-turbo package is available in Debian with one of those three names shown in the link above.
If yes, then copy paste that line into your Debian control file and re-build zoneminder.
If no, then we have more work to do to figure out what libjpeg-turbo header files we need and where they are in your flavor of Debian.
