YooSee camera
grillkoning
YooSee camera
Post by grillkoning » Wed Jul 04, 2018 2:09 pm
a lot of different hardware has the 'yoosee' label; it appears to be a chinese video-platform that supports multiple standards. I have purchased a few and got them running as follows:
assuming you know your camera' s IP address:
(1) ONVIF compatibilty:
Although it was advertised as being Onvif compatible; I had to enable this feature with my smartphone. This may differ for each camera but in my case the setting was:
[smartphone app] -> [select camera] -> settings -> security -> RTSP -> enable RTSP
you will be prompted for a password; create anything you like. You won't be using it; but the app requires you to have one anyway. Now enable access without authentication:
-> settings -> security -> RTSP -> 'no password'
(2) add to zoneminder:
- in the dashboard "add monitor"
- general: source type 'remote'
- source: '
* remote protocol: 'rtsp'
* remote method: 'rtp/ unicast'
* remote host name: [the IP address of your camera]
* remote host port: 554
* remote host path: onvif1
* capture width: 640
* capture height: 480
* deinterlacing: disabled
* use RTSP respone URL: no
tiagosoliver
Re: YooSee camera
Post by tiagosoliver » Fri Jul 12, 2019 1:56 am
Hello man, How do I add a camara yoosee, and her ip is local. ex. 192.168.0.3, if I put this ip will not work externally. I need something to put the device id.
