Hello everyone, I believe you can help me with my problem. my company bought an IP camera from the manufacturer Intelbras model VIP-5220-SD-IR. This camera has ptz functions but I can not configure it in zm.
the manufacturer's support says the camera is compatible with onvif profile "s".
I already ran wireshark while controlling for the web interface and I saw that the commands for the ptz are of the HTTP "POST" type as below:
command "left"
{"method": "ptz.start", "params": {"code": "Left", "arg1": 5, "arg2": 0, "arg3": 0, "arg4": null, "channel ": null}," id ": 679," session ": 42053615," object ": 33895736," seq ": 2175790861}
{"method": "ptz.stop", "params": {"code": "Left", "arg1": 5, "arg2": 0, "arg3": 0, "arg4": null, "channel ": null}," id ": 590," session ": 42086897," object ": 33895736," seq ": 2184311052}
command "right"
{"method": "ptz.start", "params": {"code": "Right", "arg1": 5, "arg2": 0, "arg3": 0, "arg4": null, "channel ": null}," id ": 736," session ": 42053615," object ": 33895736," seq ": 2175790863}
{"method": "ptz.stop", "params": {"code": "Right", "arg1": 5, "arg2": 0, "arg3": 0, "arg4": null, "channel ": null}," id ": 737," session ": 42053615," object ": 33895736," seq ": 2175790864}
the same for:
Up, Down, RightUp, RightDown, LeftUp, LeftDown
zoom +: ZoomTele
zoom -: ZoomWide
focus +: FocusNear
focus-: FocusFar
iris +: IrisLarge
iris-: IrisSmall
Can you help me with this question?
