Dlink DCS-8000LH
flatrick
Re: Dlink DCS-8000LH
Post by flatrick » Sun Dec 02, 2018 8:08 pm
badv990 wrote:
Wed Sep 19, 2018 10:43 pm
Post-firmware update successful settings on "D-Link DCS-8000LH/B Mini 720p HD WiFi Camera 120 Degree Wide Angle"
[General]
Source: libvlc
[Source]
Source Path: http://USERNAME:PASSWORD@xxx.xxx.xxx.xxx/video/flv.cgi
Method: TCP
Colourspace: 24-bit
Width: 1280
Height: 720
What version of the firmware are you running?
It refuses to respond to any and all URLs I've tried, and it doesn't work from VLC either so it doesn't seem to be ZoneMinder that's at fault either.
And if the link below is to be believed, these features seems to have been entirely removed (!) in the latest firmware
http://forums.dlink.com/index.php?PHPSE ... ic=73874.0
homepro
Post by homepro » Wed Dec 05, 2018 2:32 pm
Apparently it seems that all HTTP/RTSP support was removed with v2 of the firmware :(
Is there any way to downgrade to 1.X? My camera already came with v2.
unnilennium
Post by unnilennium » Sat Dec 22, 2018 11:19 pm
Here are the settings working for a version 1.01.01
with h720 codec
[General]
Source: libvlc
[Source]
Method: TCP
Colourspace: 24-bit
Width: 1280
Height: 720
with MJPEG
curl "http://USERNAME:PASSWORD@xxx.xxx.xxx.xx ... odec=MJPEG"
(if needed you can revert doing curl "http://USERNAME:PASSWORD@xxx.xxx.xxx.xx ... codec=H264" )
then
[General]
Source Type: remote
[Source]
Remote Protocol: HTTP
Remote Method: Simple
Remote Hostname: USERNAME:PASSWORD@xxx.xxx.xxx.xxx
Remote Host Port: 80
Remote Host Path: /video/mjpg.cgi
color: 24 bits
Width: 1280
Height: 720
with JPEG
[General]
Source Type: remote
[Source]
Remote Host Path: /video/jpeg.cgi
color: 24 bits
Width: 640
Height: 360
Currently I am still unable to access my camera with firmware 2.00.05 . It seems that password is randomly generated on upgrade, unless someone can confirm the old one set when still on version 1.01.01 remains.
bmork
Post by bmork » Wed May 15, 2019 10:32 am
Enabling the HTTP support is still possible in the v2 firmwares.
EDIT: Got RTSP working too. It is actualy even simpler than HTTP, since it can be permanently enabled by Bluetooth without any modifications to the firmware at all.
Please see https://github.com/bmork/defogger for a guide on how to enable RTSP, lighttpd and telnetd. The guide includes a Bluetooth tool making the mydlink app and clound unnecessary even for initial setup.
karenwillson
Post by karenwillson » Tue Jun 25, 2019 9:33 am
Thank you for the answer this information was very useful.
