IP Camera - Indoor - Dome - PTZ - Varifocal - From 2MP to 4MP
alex_peri
Post by alex_peri »
Hi everyone,
I am thinking of buying a 3 IP Cameras to cover most of my home so I need - Indoor - Dome - PTZ - Varifocal - From 2MP to 4MP.
I had a look at Dahua:
  • IPC-HDBW5431E-Z
  • IPC-HDBW5231E-Z
and Hikvision
  • DS-2CD2735FWD-IZS
  • DS-2CD2743G0-IZS
  • DS-2CD2735FWD-IZS
I could not find any that ZM explisitly supports.
  • Do you know if the any of the above work?
  • If not do you know of any other IP cameras with the following specs (Indoor - Dome - PTZ - Varifocal - From 2MP to 4MP) that do work with ZM and are reasonably priced?
Thanks,
A.
Re: IP Camera - Indoor - Dome - PTZ - Varifocal - From 2MP to 4MP
Check the Zoneminder WIKI for the camera make. Both should work.
pennyzm
Post by pennyzm »
@alex_peri,
Did you ever purchase the Hikvision PTZ camera models you mentioned and get them working?
or did you end up using something else?
I'm looking at Hikvision ptz cameras to get, but I'd like to know if you've had success with the ptz functionality.
Kind regards,
pennyzm
