AXIS Companion Dome V
dmiller
Post by dmiller » Thu Jan 04, 2018 9:12 pm
Hi!
I try to connect my new AXIS Companion Dome V cameras to ZM, 1.30.4.
But I have no luck..
Have almost tried all combinations of parameters...
Anyone having parameters for this one?
Thanks!
D
Plugmusc
Re: AXIS Companion Dome V
Post by Plugmusc » Sat Feb 24, 2018 3:55 pm
I'm having the same problem with this camera. Has anyone been able to work out the correct settings?
Many thanks,
Dave.
nilsoskar
Post by nilsoskar » Mon May 21, 2018 10:09 am
Has anyone managed to find the settings for this device?
I can connect to it if I allow Anonymous viewers but I feel it is not a long term solution.
Regards,
Nils
dmiller
Post by dmiller » Thu Oct 25, 2018 8:15 pm
How did you config Zone Minder to connect to the camera as a anonymous viewer?
What about the performance?
Regards,
Nils
snake
Post by snake » Wed Feb 20, 2019 6:48 am
It looks like the "companion series" has closed the MJPEG and RTSP urls.
Would also like to know how to connect via any means.
There is an outdoor companion cam for a reasonable price, but if it's not compatible with ZM, then I have to buy from other vendors...
