[SOLVED] DLink DCS-4703E RTSP
SFM
Post by SFM »
Hi, I have some problems to connect to a DLkink DCS 4703E with rtsp, after many testing, I'm only able to connect with rtsp if I remove authentication for rtsp on camera, with VLC Im able to connect with user and password, but I cant on zoneminder.
To connect I use these settings:
Remote
RTP/Unicast
user:password@IP
554
live1.sdp
32bit
1920
1080
That only works if I remove the authentication on camera, if not, ZM registry says theres no RTSP source.
Any advice or suggestion? I would prefer to have authentication activated on camera.
Thanks in advance, and congrats for your great work on this great soft.
Re: DLink DCS-4703E RTSP
Use ffmpeg source type.
SFM
Post by SFM »
I'm unable to connect as ffmpeg source type
IP:554/live1.sdp
UDP
Log says Unable to open input IP:554/live1.sdp due to: Connection timed out
SFM
Post by SFM »
Nevermind, I success after some changes
rtsp://user:password@IP:554/live1.sdp
UDP
