Hikvision DS-2CD3325 not working on ZoneMinder 1.30.2
TheEiledon
Post by TheEiledon »
I have set up as per the wiki and experimented with the settings which are currently:
General tab:
Source Type: Ffmpeg
Maximum FPS: Not Set
Source tab:
Source Path: rtsp://admin:xxxxxxx@192.168.0.xxx4:554/cam/realmonitor?channel=1&subtype=0
Remote Method: TCP
Options: Empty
Target Colorspace: 24 bit colour
Capture Width (pixels): 1920 was 1280
Capture Height (pixels): 1080 was 720
Preserve Aspect Ratio: Not Checked
Orientation: Normal
Deinterlacing: Disabled
However, on trying to connect I get this:
zmc_m3[9318]: ERR [Unable to open input rtsp://admin:xxxxxxxxx@192.168.0.xxx due to: Connection reset by peer]
Is the problem that my Remote Method is TCP? I have don't have an RTP/RTSP option?
montagdude
Re: Hikvision DS-2CD3325 not working on ZoneMinder 1.30.2
Post by montagdude »
Have you tried to see if you can view the stream with VLC or something else other than ZoneMinder?
Regarding the remote method, as I understand it, the RTP/RTSP option went away somewhere in the 1.30 releases. My Amcrest cameras have a web interface that lets you change a whole bunch of settings, including the remote method, which I have set to TCP. Does your camera have something like that?
TheEiledon
Thanks for replying. Yes VLC Network Stream works fine. I will take a further look at the camera settings regarding Remote Method.
