ERR: Only read XXXX bytes of YYYY and "Incomplete frame write" Errors
SpikeyGG
Post by SpikeyGG »
So I'm running ZM 1.30.4 and it looks like I'm getting a lot of this kind of stuff:
Date/Time		Component	Server	PID	Level	Message								File		Line
11/4/17 11:14 AM	zmf			12781	WAR	Socket closed at remote end					zmf.cpp		312
11/4/17 11:14 AM	zmf			12781	ERR	Only read 219224 bytes of 979149				zmf.cpp		305
11/4/17 11:14 AM	zma_m3			12785	ERR	Incomplete frame write: 219264 of 979189 bytes written		zm_event.cpp	342
11/4/17 11:14 AM	zmf			12781	ERR	Only read 219224 bytes of 977295				zmf.cpp		305
11/4/17 11:14 AM	zma_m3			12785	ERR	Incomplete frame write: 219264 of 977335 bytes written		zm_event.cpp	342
I have an IP camera (RLC-410) and it appears to only spit out these error messages when it's capturing an alarmed event, when it's idle it seems to be fine and everything appears to be working correctly. Any idea how to solve these error messages? When they come they come in bulk! Looks like every alarm frame contains an error.
I've attached a longer example screen capture of the log for your viewing pleasure...
Thanks,
-Greg
ZM Errors.PNG (111.48 KiB) Viewed 5575 times
mcmellenhead
Re: ERR: Only read XXXX bytes of YYYY and "Incomplete frame write" Errors
Post by mcmellenhead »
+1 for this issue. Same camera. Same error in the logs
How do you have the camera configured? Which Linux distro and version?
SpikeyGG
Post by SpikeyGG »
bbunge wrote: Mon Dec 04, 2017 12:49 pm How do you have the camera configured? Which Linux distro and version?
The camera is throttled at 6fps and 720p on my setup. I have 5 zones with varying amounts of blob detection in each zone. I'm using RTP/RTSP with the hardcoded IP of the camera using the standard port 554. I'm not sure what kind of details you're looking for on the camera end.
The OS I'm using is Ubuntu:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.3 LTS
Release:        16.04
Codename:       xenial
For starters, turn off the frame server under options.
The frame server ends up causing more problems than it attempts to solve.
It has been removed from the latest master branch, and won't be part of the next release of ZoneMinder.
SpikeyGG
Post by SpikeyGG »
knnniggett wrote: Mon Dec 11, 2017 9:35 pm For starters, turn off the frame server under options.
I just modified that setting on my setup. I'll monitor over the next month and report back.
Excellent. Keep us posted. Best case, that was the root cause of the problem. Worse case, all that noise in your log was masking the root cause of the problem. In either case, progress has been made.
SpikeyGG
Post by SpikeyGG »
Okay, it looks like the original warnings/errors disappeared but now I'm seeing "Unexpected channel selector XXX in RTSP interleaved data" errors and a few other warnings... Here's a screen shot:
ZM Errors2.png (118.82 KiB) Viewed 5313 times
I did some googling around for the error and I found a few threads but no one seems to have a fix. :(
Any ideas?
These are the types of warning messages:
Unexpected format RTSP interleaved data, resyncing by VVV bytes
Discarding incomplete frame WWWWW, 0 bytes
Discarding partial frame XXXXX, YYYYY bytes
Packet in sequence, gap ZZ
Yes, don't use the Remote -> RTSP method. This method is no longer being maintained as it attempts to recreate the wheel.
The errors you see are exactly why our documentation states to use a source type of ffmpeg for rtsp devices:
http://zoneminder.readthedocs.io/en/sta ... nitor.html
NOTE: Have you tried the ONVIF probe? If it finds your camera, it will program the monitor for you (using ffmpeg source type).
SpikeyGG
Post by SpikeyGG »
knnniggett wrote: Sat Dec 16, 2017 3:12 pm Yes, don't use the Remote -> RTSP method. This method is no longer being maintained as it attempts to recreate the wheel.
Thanks for the quick response! I have swapped my camera over to using ffmpeg. I will monitor this setup and report back.
SpikeyGG
Post by SpikeyGG »
Yeah, I think that did it knnniggett. Thanks for your help with this... my logs thank you! :)
